I am trying to integrate Google Calendar with Home Assistant, but the OAuth flow consistently fails with:
Error 400: redirect_uri_mismatch
Setup
2026.4.2
- Home Assistant running behind Cloudflare Tunnel
- External URL:
https://mydomain.aa - Internal URL:
http://192.168.1.xx:8123 - Using Google Cloud OAuth credentials (Web application)
- Google Calendar API is enabled
- Home Assistant is accessed publicly via the domain successfully (works from mobile 4G)
Configuration (Home Assistant)
homeassistant: internal_url: "http://192.168.1.xx:8123" external_url: "https://mydomain.aa"http: use_x_forwarded_for: true trusted_proxies: - 172.30.33.0/24 - 127.0.0.1 - ::1
### Problem
When starting the Google Calendar integration, the OAuth flow redirects to:
https://my.home-assistant.io/redirect/oauth
instead of the expected callback URL:
https://mydomain.ch/auth/external/callback
This causes Google to reject the authentication with:
### What I already tried
* Verified Google Cloud OAuth redirect URI configuration
* Ensured correct external URL in Home Assistant
* Removed and recreated Google integration
* Restarted Home Assistant
* Cleared browser cache
* Confirmed Cloudflare Tunnel is working correctly
* Confirmed HTTPS access to Home Assistant domain works externally
### Expected behavior
Home Assistant should use:
https://mydomain.aa/auth/external/callback
as the OAuth redirect URI.
### Actual behavior
Home Assistant uses:
which causes the mismatch in Google OAuth.
If anyone has seen this with Cloudflare Tunnel + Home Assistant Google integration, I would appreciate guidance on what is forcing the my.home-assistant.io redirect instead of the configured external URL
if cloudflare is not supported with google calendar, should be written somewhere in the documentation
