I have a bunch of google home devices (home, home mini, and a third party portable speaker).
I’m using discovery to find all the devices - which is great. Except the portable speaker isn’t always powered/on. And so if HA is restarted, the discovery fails to find it, and lovelace complains
No state available for media_player.portable_speaker
The device does show in the discovery integrations, although as entity unavailable.
SO - how to fix? Do I just need to give it a static IP and list it manually under media_players: ?
Guess you could manually list it with an IP address but if it’s not available it probably still will show with the same message on Lovelace.
Maybe you could create a template sensor that check’s the state of the media_player and use this to conditionally display the media_player?
Something along the lines of:
