Google Cloud SSML not working
Hello! Just trying to integrat SSML into my HA.
action: tts.speak
  entity_id: tts.google_cloud
  cache: false
  media_player_entity_id: media_player.dressing_room_speaker
  message: "<speak>Good morning, Home Assistant. The time is now <say-as interpret-as='time'>12:43 PM</say-as>.</speak>"
  options:
    voice: en-US-Chirp3-HD-Iapetus
    text_type: ssml
When I try to run anything with SSML, I get zero response and zero errors. Jut nothing happens. If I remove the text_type is speaks fin, but obviously without the SSML formatting.
What am I missing?
Thanks!
Hmm, anyone have experience with this? I’ve tried copying YAML from other examples but I can’t get any to run.
Something broke very recently. When I try tts.speak with tts.google_cloud, it throws the below error:
Failed to perform the action tts.speak. value must be one of ['', 'af-ZA-Standard-A', 'am-ET-Standard-A', 'am-ET-Standard-B', 'am-ET-Wavenet-A', 'am-ET-Wavenet-B', 'ar-XA-Chirp3-HD- ...CUT...'yue-HK-Standard-D'] for dictionary value @ data['voice']. Got None
Just two days ago my scripts worked, so I assume google changed something in their API?
There is already a bug reported on github: Google TTS throws error · Issue #146043 · home-assistant/core · GitHub
The suggested fix there worked for me. Just reconfigure and make sure you have a default voice selected.
Thanks. I actually found that too, and got it working. But for this problem, it’s just the SSML that I can’t get to work.
That link did help me get Google Cloud working again though. Just not the SSML part. No errors are being thrown in this case
Sorry, I misread your original question :grimacing:
Does it work if you remove the options? The below code works for me, but it doesn’t if I add the options.
action: tts.speak
  cache: true
  media_player_entity_id: media_player.living_room_speaker
  message: >-
It did used to work for me even with the options before, but now I also can only get it to work if I remove the options.
BTW: I see you use a Chirp3 voice. When I switch to a Chirp3 voice, ssml tags don’t seem to work. Ssml tags seem to only work with wavenet or standard voices for me.
Yeah, I think that may be part of the problem. If you try changing the pitch for a Chirp voice, it also fails. Those new voices must not work with anything other than the speed option. Thanks for looking into it
Short version, chirp does not support SSML and Google can’t tell me when/if it will.
