Google Coral AI issues
Hi everyone,
I don’t acheive to make my Google Coral USB work for my frigate installation. I’m not sure to be in the good topics so if i’m wrong don’t hesite to tell me :slight_smile:
This is my installation for now:
  • Hardware : Intel NUC
  • Software :
    • Proxmox installed on it
    • VM for Home Assistant
    • LXC for frigate and Portainer on it to launch frigate container.
I follow this tuto : https://www.saninnsalas.com/passing-google-coral-usb-edge-tpu-to-an-unprivileged-container-in-proxmox/
Then I modified my docker image like this :
version: "3.9"
services:
  frigate:
    container_name: frigate
    privileged: true # this may not be necessary for all setups
    restart: unless-stopped
    image: ghcr.io/blakeblackshear/frigate:stable
    shm_size: "256mb" # update for your cameras based on calculation above
    devices:
      - /dev/bus/usb:/dev/bus/usb # passes the USB Coral, needs to be modified for other versions
      #- /dev/apex_0:/dev/apex_0 # passes a PCIe Coral, follow driver instructions here https://coral.ai/docs/m2/get-started/#2a-on-linux
      - /dev/dri/renderD128 # for intel hwaccel, needs to be updated for your hardware
    volumes:
      - /etc/localtime:/etc/localtime:ro
      - /opt/frigate/config.yml:/config/config.yml
      - /opt/frigate/storage:/media/frigate
      - type: tmpfs # Optional: 1GB of memory, reduces SSD/SD Card wear
        target: /tmp/cache
        tmpfs:
    ports:
      - "5000:5000"
      - "8554:8554" # RTSP feeds
      - "8555:8555/tcp" # WebRTC over tcp
      - "8555:8555/udp" # WebRTC over udp
    #environment:
    #  FRIGATE_RTSP_PASSWORD: "password"
And finally I modified my Frigate configuration file with this :
detectors:
  coral:
    type: edgetpu
    device: usb
With this configurations I have my frigate container which is loop in “start, error and stop” with this mesage :
2025-03-05 20:37:44.027441407  [INFO] Starting Frigate...
s6-rc: info: service legacy-services successfully started
2025-03-05 20:37:44.369198788  127.0.0.1 - - [05/Mar/2025:20:37:44 +0000] "" 400 0 "-" "-" "-"
2025-03-05 20:37:45.017727749  [INFO] Starting go2rtc...
2025-03-05 20:37:45.215838615  20:37:45.215 INF go2rtc platform=linux/amd64 revision=b2399f3 version=1.9.2
2025-03-05 20:37:45.215979933  20:37:45.215 INF config path=/dev/shm/go2rtc.yaml
2025-03-05 20:37:45.217027939  20:37:45.216 INF [api] listen addr=:1984
2025-03-05 20:37:45.217256851  20:37:45.216 INF [rtsp] listen addr=:8554
2025-03-05 20:37:45.217971946  20:37:45.217 INF [webrtc] listen addr=:8555/tcp
2025-03-05 20:37:47.785243960  2025/03/05 20:37:47 [error] 161#161: *2 connect() failed (111: Connection refused) while connecting to upstream, client: 192.168.1.30, server: , request: "GET /api/stats HTTP/1.1", subrequest: "/auth", upstream: "http://127.0.0.1:5001/auth", host: "192.168.1.38:5000"
2025-03-05 20:37:47.785253309  2025/03/05 20:37:47 [error] 161#161: *2 auth request unexpected status: 502 while sending to client, client: 192.168.1.30, server: , request: "GET /api/stats HTTP/1.1", host: "192.168.1.38:5000"
2025-03-05 20:37:51.655464961  [2025-03-05 20:37:51] frigate.util.config            INFO    : Checking if frigate config needs migration...
2025-03-05 20:37:51.740439903  [2025-03-05 20:37:51] frigate.util.config            INFO    : frigate config does not need migration...
2025-03-05 20:37:51.964260485  [2025-03-05 20:37:51] frigate.util.services          WARNING : Did not detect hwaccel, using a GPU for accelerated video decoding is highly recommended
2025-03-05 20:37:52.007060881  [2025-03-05 20:37:52] frigate.app                    INFO    : Starting Frigate (0.15.0-cea210d)
2025-03-05 20:37:52.057966151  [2025-03-05 20:37:52] peewee_migrate.logs            INFO    : Starting migrations
2025-03-05 20:37:52.059112344  [2025-03-05 20:37:52] peewee_migrate.logs            INFO    : There is nothing to migrate
2025-03-05 20:37:52.090541425  [2025-03-05 20:37:52] frigate.app                    INFO    : Recording process started: 351
2025-03-05 20:37:52.090735429  [2025-03-05 20:37:52] frigate.app                    INFO    : Review process started: 358
2025-03-05 20:37:52.101662809  [2025-03-05 20:37:52] frigate.app                    INFO    : go2rtc process pid: 98
2025-03-05 20:37:52.138260661  [2025-03-05 20:37:52] detector.coral                 INFO    : Starting detection process: 367
2025-03-05 20:37:52.786714602  2025/03/05 20:37:52 [error] 162#162: *4 connect() failed (111: Connection refused) while connecting to upstream, client: 192.168.1.30, server: , request: "GET /api/stats HTTP/1.1", subrequest: "/auth", upstream: "http://127.0.0.1:5001/auth", host: "192.168.1.38:5000"
2025-03-05 20:37:52.786722889  2025/03/05 20:37:52 [error] 162#162: *4 auth request unexpected status: 502 while sending to client, client: 192.168.1.30, server: , request: "GET /api/stats HTTP/1.1", host: "192.168.1.38:5000"
2025-03-05 20:37:53.697778619  [INFO] Starting go2rtc healthcheck service...
2025-03-05 20:38:17.464473940  [2025-03-05 20:37:52] frigate.app                    INFO    : Output process started: 386
2025-03-05 20:38:17.464517648  [2025-03-05 20:37:52] frigate.detectors.plugins.edgetpu_tfl INFO    : Attempting to load TPU as usb
2025-03-05 20:38:17.464822647  [2025-03-05 20:37:52] frigate.app                    INFO    : Camera processor started for camera_devant: 400
2025-03-05 20:38:17.466896002  [2025-03-05 20:37:52] frigate.app                    INFO    : Camera processor started for camera_arriere: 403
2025-03-05 20:38:17.466904875  [2025-03-05 20:38:17] frigate.detectors.plugins.edgetpu_tfl ERROR   : No EdgeTPU was detected. If you do not have a Coral device yet, you must configure CPU detectors.
2025-03-05 20:38:17.466912076  [2025-03-05 20:37:52] frigate.app                    INFO    : Camera processor started for camera_cabanon: 405
2025-03-05 20:38:17.466915884  [2025-03-05 20:37:52] frigate.app                    INFO    : Capture process started for camera_devant: 416
2025-03-05 20:38:17.466984055  [2025-03-05 20:37:52] frigate.app                    INFO    : Capture process started for camera_arriere: 438
2025-03-05 20:38:17.466987669  [2025-03-05 20:37:52] frigate.app                    INFO    : Capture process started for camera_cabanon: 446
2025-03-05 20:38:17.467052653  [2025-03-05 20:37:55] frigate.api.fastapi_app        INFO    : Starting FastAPI app
2025-03-05 20:38:17.467202352  [2025-03-05 20:37:56] frigate.api.fastapi_app        INFO    : FastAPI started
2025-03-05 20:38:17.474674792  Process detector:coral:
2025-03-05 20:38:17.474682128  Traceback (most recent call last):
2025-03-05 20:38:17.474684579    File "/usr/lib/python3/dist-packages/tflite_runtime/interpreter.py", line 160, in load_delegate
2025-03-05 20:38:17.474686268      delegate = Delegate(library, options)
2025-03-05 20:38:17.474688385    File "/usr/lib/python3/dist-packages/tflite_runtime/interpreter.py", line 119, in __init__
2025-03-05 20:38:17.474690086      raise ValueError(capture.message)
2025-03-05 20:38:17.474691490  ValueError
2025-03-05 20:38:17.474692830
2025-03-05 20:38:17.474694667  During handling of the above exception, another exception occurred:
2025-03-05 20:38:17.474695946
2025-03-05 20:38:17.474697499  Traceback (most recent call last):
2025-03-05 20:38:17.474699448    File "/usr/lib/python3.9/multiprocessing/process.py", line 315, in _bootstrap
2025-03-05 20:38:17.474700922      self.run()
2025-03-05 20:38:17.474702860    File "/opt/frigate/frigate/util/process.py", line 41, in run_wrapper
2025-03-05 20:38:17.474706108      return run(*args, **kwargs)
2025-03-05 20:38:17.474708062    File "/usr/lib/python3.9/multiprocessing/process.py", line 108, in run
2025-03-05 20:38:17.474796392      self._target(*self._args, **self._kwargs)
2025-03-05 20:38:17.474799900    File "/opt/frigate/frigate/object_detection.py", line 121, in run_detector
2025-03-05 20:38:17.474802391      object_detector = LocalObjectDetector(detector_config=detector_config)
2025-03-05 20:38:17.474804290    File "/opt/frigate/frigate/object_detection.py", line 68, in __init__
2025-03-05 20:38:17.474806224      self.detect_api = create_detector(detector_config)
2025-03-05 20:38:17.474808207    File "/opt/frigate/frigate/detectors/__init__.py", line 18, in create_detector
2025-03-05 20:38:17.474809767      return api(detector_config)
2025-03-05 20:38:17.474848142    File "/opt/frigate/frigate/detectors/plugins/edgetpu_tfl.py", line 41, in __init__
2025-03-05 20:38:17.474851351      edge_tpu_delegate = load_delegate("libedgetpu.so.1.0", device_config)
2025-03-05 20:38:17.474853559    File "/usr/lib/python3/dist-packages/tflite_runtime/interpreter.py", line 162, in load_delegate
2025-03-05 20:38:17.474855735      raise ValueError('Failed to load delegate from {}\n{}'.format(
2025-03-05 20:38:17.474857550  ValueError: Failed to load delegate from libedgetpu.so.1.0
2025-03-05 20:38:17.474858827
2025-03-05 20:38:25.593038531  [2025-03-05 20:38:25] frigate.watchdog               INFO    : Detection appears to have stopped. Exiting Frigate...
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service go2rtc-healthcheck: stopping
s6-rc: info: service certsync: stopping
2025-03-05 20:38:25.620126390  [INFO] The go2rtc-healthcheck service exited with code 256 (by signal 15)
s6-rc: info: service go2rtc-healthcheck successfully stopped
2025-03-05 20:38:25.627817624  [INFO] Service CERTSYNC exited with code 256 (by signal 15)
s6-rc: info: service certsync successfully stopped
s6-rc: info: service nginx: stopping
s6-rc: info: service certsync-log: stopping
s6-rc: info: service certsync-log successfully stopped
2025-03-05 20:38:25.713108374  [INFO] Service NGINX exited with code 0 (by signal 0)
s6-rc: info: service nginx successfully stopped
s6-rc: info: service nginx-log: stopping
s6-rc: info: service frigate: stopping
s6-rc: info: service nginx-log successfully stopped
2025-03-05 20:38:25.872211909  [2025-03-05 20:38:25] frigate.app                    INFO    : Stopping...
2025-03-05 20:38:25.878208557  [2025-03-05 20:38:25] frigate.watchdog               INFO    : Exiting watchdog...
2025-03-05 20:38:25.878216957  [2025-03-05 20:38:25] frigate.record.cleanup         INFO    : Exiting recording cleanup...
2025-03-05 20:38:25.878219432  [2025-03-05 20:38:25] frigate.events.cleanup         INFO    : Exiting event cleanup...
2025-03-05 20:38:25.878221590  [2025-03-05 20:38:25] frigate.stats.emitter          INFO    : Exiting stats emitter...
2025-03-05 20:38:25.878223706  [2025-03-05 20:38:25] frigate.ptz.autotrack          INFO    : Exiting autotracker...
2025-03-05 20:38:25.878225905  [2025-03-05 20:38:25] frigate.storage                INFO    : Exiting storage maintainer...
2025-03-05 20:38:25.880896723  [2025-03-05 20:38:25] frigate.app                    INFO    : Waiting for capture process for camera_devant to stop
2025-03-05 20:38:25.886466535  [2025-03-05 20:38:25] watchdog.camera_devant         INFO    : Terminating the existing ffmpeg process...
2025-03-05 20:38:25.887475404  [2025-03-05 20:38:25] watchdog.camera_devant         INFO    : Waiting for ffmpeg to exit gracefully...
2025-03-05 20:38:26.220530750  [2025-03-05 20:38:26] frigate.app                    INFO    : Waiting for capture process for camera_arriere to stop
2025-03-05 20:38:26.222227529  [2025-03-05 20:38:26] watchdog.camera_arriere        INFO    : Terminating the existing ffmpeg process...
2025-03-05 20:38:26.222715584  [2025-03-05 20:38:26] watchdog.camera_arriere        INFO    : Waiting for ffmpeg to exit gracefully...
2025-03-05 20:38:26.496347873  [2025-03-05 20:38:26] frigate.object_processing      INFO    : Exiting object processor...
2025-03-05 20:38:26.574152809  [2025-03-05 20:38:26] frigate.events.maintainer      INFO    : Exiting event processor...
2025-03-05 20:38:26.776484635  [2025-03-05 20:38:26] frigate.app                    INFO    : Waiting for capture process for camera_cabanon to stop
2025-03-05 20:38:26.779782942  [2025-03-05 20:38:26] watchdog.camera_cabanon        INFO    : Terminating the existing ffmpeg process...
2025-03-05 20:38:26.780360857  [2025-03-05 20:38:26] watchdog.camera_cabanon        INFO    : Waiting for ffmpeg to exit gracefully...
2025-03-05 20:38:26.976621761  [2025-03-05 20:38:26] frigate.app                    INFO    : Waiting for process for camera_devant to stop
Could you tell me what I’m doing wrong ? Do I miss something on configuration side ?
Thanks you very much for your help.
