Google Generative AI responds very late
Google Generative AI responds very late. Sometimes it takes up to 1 hour. I wonder why this delay occurs?
An hour… that is slow. :thinking:
Can you give more details about how your system is set up and what hardware you’re using?
My system is installed on Pi4, but today I did a clean install on Pi5 and first installed the Google Generative AI plugin, and the same problem continues on the clean install and Pi5.
And a bit more…? :grin:
I performed a fresh installation on the Pi5 hardware using an M.2 SSD. During the initial setup, I configured the settings required by Home Assistant and only added the Google Generative AI add-on by creating an API key. Then, I sent a query using Google Generative AI: Generate Content from the Actions section. In this query, I simply wrote “hi,” and the response took about 10-15 minutes to arrive.
Before making the query, I enabled debug logging, and the only log that appeared was the one below. Since this was a test setup, I had previously powered off the device by cutting the electricity. The log only contains this output, and I couldn’t find any log related to the delay.
What should I do? Is there anything specific you want me to do or any information you need?
2025-03-23 02:21:41.350 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2025-03-23 02:21:41.374 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=5 from 2025-03-22 18:06:03.079153)
By the way, my internet speed is 1 gbps for download and upload.
I’ve identified the root cause of the issue. I downgraded the Home Assistant Core version to an older version, 2025.2.5, and it started responding very quickly again, just like before. With version 2025.3, there was a change in the Google Generative AI integration, as shown below, and with 2025.3 and later versions, the response time started to increase. Where should I report this?
Older version
New version (Attachment filenames added)
