I’ve exposed my Marantz SR5011 to Google Home via the Nabu Casa cloud and it has been working just fine up until recently. The Home app used to see the amplifier as a dimmable light and I could issue voice commands to Google Home to adjust the amplifier to a certain percentage. Awesome.
Now the amplifier just shows up as a light, no dim effect available. Pretty crap.
I’ve tried to remove it and add it back to Google Home, but it’s all the same. Just a power button. No slider to adjust volume/brightness.
I’m not sure exactly which version that broke this, but it must have been around 0.93.
Is there any way to force it to show up as a dimmable light for Google? I’ve tried reading around, but can’t find any way to do that.
No problem here with my Denon, indeed something changed a few weeks ago in 92, Media player is now exposed as a volume threat instead of a light… It’s working for me
Media players have been updated to be a switch and have the volume trait exposed to Google Assistant, so you can turn them on/off and adjust the volume instead of the former brightness hack that was in place.
Can you provide a link to the PR or some instructions on how to configure denon with hassio and google assistant to regain volume control. I have not been able to locate any mention on this anywhere.
Doesn’t work for me. Google still think me denon is simply a switch.!
Here is a screenshot of the interface in the app. Does it look the same on your Google Home app?
If you check under Cloud and Manage entities, does it says Volume as a trait? Mine says OnOff, Modes, Volume. Not sure what “Modes” are, but Volume works for increasing and lowering the volume, but I can’t tell it to set a specific volume. Annoying as hell.
EDIT:
Modes are sources apparently: https://developers.google.com/assistant/smarthome/traits/modes
EDIT2: This might be Google assistant in Swedish that has hade some weird command change. The old commands for “volume amplifier xx” doesn’t work anymore. Also “set volume of amplifier to xx” doesn’t work, but “set THE volume of amplifier to xx” works. In Swedish that is.
When I try to adjust the volume of the stereo like:
“hey google, set the stereo to 50%” --> Sets the volume of the google home device I am talking to.
or
“hey google, set the volume of stereo to 50%” responds with: “sorry, I did not understand that”.
