Google Home integration issues/error
the Google Home integration kicks up errors upon Core restart:
Logger: homeassistant.setup
Source: setup.py:202
First occurred: 6:32:25 AM (1 occurrences)
Last logged: 6:32:25 AM
Setup failed for custom integration google_home: Requirements for google_home not found: ['glocaltokens==0.6.3'].
Additionally, if I’m unable to remove it from the Integrations screen. When I click on three dots >> Delete >> Delete? Dialog: Delete nothing happens. If I click on Add Integration >> Google Home . I get the following error:
Error
Config flow could not be loaded: 500 Internal Server Error Server got itself in trouble
I’m at a loss here. Fingers crossed on this one. Thanks in advance!
Did you check the GitHub repo for that custom component to see if there’s known issues?
