Google Home Invalid Config
After core update Google Home doesn’t work.
Home Assistant Core: Logger: homeassistant.setup
Bron: setup.py:278
Eerst voorgekomen: 18:28:58 (1 gebeurtenis)
Laatst gelogd: 18:28:58
Setup failed for custom integration ‘google_home’: Requirements for google_home not found: [‘glocaltokens==0.7.4’].
Reload via HACS or older version doesn’t fix it.
Hardware: Home Assistant Blue / Hardkernel ODROID-N2/N2+
odroid-n2
Looks like that’s linked to this: glocaltokens · Issue #951 · leikoilja/ha-google-home · GitHub
Thanks for pointing me to this. It’s the same issue. It’s not the solution but this post can be closed. Only solution now is to roll back using ssh: ha core update --version 2025.6.3 and ignore Core update 2025.7.0
