Logger: locationsharinglib.Service
Source: /usr/local/lib/python3.8/site-packages/locationsharinglib/locationsharinglib.py:170
First occurred: 8:14:24 AM (47 occurrences)
Last logged: 9:00:24 AM
Received response code:500
I tried recreating the cookie, as well as commenting out configuration.yaml entries and rebooting numerous times w/ different iterations of installed / removed / commenting out known_devices.yaml
Anyone else seeing this issue / know how to resolve? Figured Iād ask here before posting to Git. Thanks in advance!
Iām still on .118.5 and running Ubuntu 20.04.1 LTS. Happy to post it, but assuming Iām going to get yelled at for running and outdated version and unsupported systemā¦
I have the same issue with the latest Home Assistant version. āReceived response code:500ā ā¦over 500 ocurrenes. I tried getting āfreshā cookies, still same error. I think it started recently ( maybe 1 day?).
Thx for creating the Git issue. I commented w/ the error Iām receiving in my logs as well. Hoping itās fixed soon - home / away definitely a critical component of dozens of my automationsā¦
If you use docker version, hereās my barbaric attempt to band-aid this using Dockerfile:
FROM homeassistant/home-assistant:2021.1.1
RUN sed -i "s|requests==2.25.0|requests==2.25.1|g" /usr/src/homeassistant/requirements.txt
RUN sed -i "s|requests==2.25.0|requests==2.25.1|g" /usr/src/homeassistant/homeassistant/package_constraints.txt
RUN sed -i "s|requests==2.25.0|requests==2.25.1|g" /usr/src/homeassistant/setup.py
RUN sed -i "s|locationsharinglib==4.1.0|locationsharinglib==4.1.5|g" /usr/src/homeassistant/requirements_all.txt
RUN sed -i "s|locationsharinglib==4.1.0|locationsharinglib==4.1.5|g" /usr/src/homeassistant/homeassistant/components/google_maps/manifest.json
RUN pip install requests==2.25.1 locationsharinglib==4.1.5
Use build: . in your docker-compose instead of image: homeassistant/home-assistant:2021.1.1 and put Dockerfile alongside with docker-compose.yml
Iām not very familiar with how the homeassistant setup works but without replacing versions in actual files it keeps reinstalling old versions of specified libs on every restart.
Alternatively, you can simply risk and run dev-version, which I chose not to do.
(The problem is fixed in locationsharinglib==4.1.5, which is adopted in dev-version of hass-core, but not released yet)
Hi Boomka,
Thanks for sharing as Iām also looking forward to get this working.
I use the location in HA to alert me of my kid returning and going to school.
ā¦ a real impact here at home ā¦
hope that new version would be avaialble in the short
Glad Iām not the only one that this has impacted. As an FYI, for anyone attempting to pinpoint the time this changed over - it was approx 12:17 GMT+8 on 12/1/21.
I too use this for a couple of automations and had to go back to doing things manually. Ugh, such a drag!
I would ask if @dshokouhi can please clarify his ānext major releaseā comment from Git. Does this mean 2021.1.2 or 2021.2.0?
The latter is clearly > 2 weeks away and this (at least for me) is a MAJOR issue not knowing if myself / wife / kids are home or away.
I know I personally have dozens of automations that depend on it (one such automation did not set my home alarm last night as an exampleā¦). Thx for any insight you can provide Daniel!
@Markus99 I feel your pain. I am an avid user of the Google Maps integration, but then also have owntracks as a backstop in addition to bluetooth device_tracker on all our phones. Either way, the Maps integration is the most informative and reliable. Fingers that the fix is a subversion release and not coming next month.
if you guys have an android device consider using the companion app, our device tracker also uses googles fused location services and we have done lots of improvements to it recently.
I agree, I know thereās other services and I also have some of them implemented but this is a major break in the reliability of my device tracking setup. Hopefully the fix can get pushed up to 2021.1.2
I do, fortunately, run Android, but currently donāt use the companion app, simply a bookmark to my DuckDNS URL and it works great. I personally despise addāl apps that are redundant and clutter my phone (ie. I use FB via web URL vs. their app). Definitely appreciate the interim fix suggestion.
If this is the only / best solution - then Iāll explore - but also guessing it requires addāl user setup and such vs. just āworkingā as google_maps integrations has to date. I also realize I can setup owntracks, Google Wifi, bluetooth device trackers and the rest. I further realize this is working ābetaā software, just a critical component for many Iād guesstimate.
Any suggestions for how / where to strongly suggest to the powers that be to bump this up to 2021.1.2 vs the Feb 2021.2.0 release?
