Google Nest Camera Integration Intermittently Fails
I have had my google nest doorbell (battery) setup using the Google nest integration. This worked for around two years until I started experiencing problems. Around late December or early January of this year, the nest integration stopped working and I get this error:
Logger: homeassistant.components.nest
Source: components/nest/__init__.py:301
integration: Google Nest (documentation, issues)
First occurred: 7:09:40 PM (16 occurrences)
Last logged: 7:43:15 PM
Subscriber error: Unexpected error when calling streaming_pull: Timeout in streaming_pull
Mid January, I deleted my credentials, did nothing for a week, and when I went to re-add the integration everything worked again. Then last week, the nest integration stopped working and I am getting the same error. Some things of note: When the integration first failed, my connection to google calendar, gemini, and google keep (through a custom integration) all stopped working at the same time. With the latest failure, only Nest and Google Keep Sync have stopped working. I can see the API requests on the google cloud console, but almost all requests result in errors. Any help resolving this would be much appreciated!
