Google nest thermostat integration not updating based on changes outside homeassistant
In another topic I can no longer reply to as I am a “new” user there seem to be some users who have issues with the google nest integration in relation to thermostats.
I have a relatively clean install within the last couple of weeks. The integration has picked up my thermostats, but the thermostat changes made manually or in the nest app never update the integration. I can change the thermostat temperature in the integration, and the furnace kicks in meaning the auth seems to be working. It just seems to be the retrieval of updates outside of home-assistant which are the problem. I enabled debug logging and pasted much below. I did stop this which seems suspicious.
2025-03-21 09:51:34.526 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Sending streaming pull request (acking 0 messages)
2025-03-21 09:52:56.826 DEBUG (MainThread) [google_nest_sdm.subscriber_client] API error in streaming pull: 503 The service was unable to fulfill your request. Please try again. [code=8a75]
2025-03-21 09:52:56.827 DEBUG (MainThread) [google_nest_sdm.streaming_manager] Disconnected from event stream: API error when streaming iterator: 503 The service was unable to fulfill your request. Please try again. [code=8a75]
2025-03-21 09:52:56.827 DEBUG (MainThread) [google_nest_sdm.streaming_manager] Reconnecting stream in 10.0 seconds
Let me know what other information I can gather to help track this down.
Larger log:
2025-03-21 09:29:46.898 DEBUG (MainThread) [google_nest_sdm.auth] request[post]=https://smartdevicemanagement.googleapis.com/v1/enterprises/c141e887-5c5c-4922-9a34-14facc47c7c3/devices/AVPHwEtagKfxkGCoPtBW7Mx4A_7vqy8Oihak4_7zMZQJ42WJbeNzIhUCAp0qpmHjXCR5y-5DrfyPDiiD79VTqG32uy5LtA:executeCommand
2025-03-21 09:29:46.898 DEBUG (MainThread) [google_nest_sdm.auth] request[post json]={'command': 'sdm.devices.commands.ThermostatTemperatureSetpoint.SetHeat', 'params': {'heatCelsius': 21.11111111111111}}
2025-03-21 09:30:00.713 DEBUG (MainThread) [google_nest_sdm.auth] request[post]=https://smartdevicemanagement.googleapis.com/v1/enterprises/c141e887-5c5c-4922-9a34-14facc47c7c3/devices/AVPHwEtagKfxkGCoPtBW7Mx4A_7vqy8Oihak4_7zMZQJ42WJbeNzIhUCAp0qpmHjXCR5y-5DrfyPDiiD79VTqG32uy5LtA:executeCommand
2025-03-21 09:30:00.713 DEBUG (MainThread) [google_nest_sdm.auth] request[post json]={'command': 'sdm.devices.commands.ThermostatTemperatureSetpoint.SetHeat', 'params': {'heatCelsius': 20.0}}
2025-03-21 09:30:17.850 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Sending streaming pull request (acking 0 messages)
2025-03-21 09:30:57.212 DEBUG (MainThread) [google_nest_sdm.streaming_manager] Stopping subscription projects/first-strength-448400-n4/subscriptions/home-assistant-ftgOCd1bFZ
2025-03-21 09:30:57.221 DEBUG (MainThread) [google_nest_sdm.streaming_manager] Subscription loop cancelled
2025-03-21 09:30:57.224 DEBUG (MainThread) [google_nest_sdm.google_nest_subscriber] Starting subscription projects/first-strength-448400-n4/subscriptions/home-assistant-ftgOCd1bFZ
2025-03-21 09:30:57.224 DEBUG (MainThread) [google_nest_sdm.streaming_manager] Connecting with streaming pull
2025-03-21 09:30:57.224 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Credentials refreshed, new expiry 2025-03-21 10:25:47.986864
2025-03-21 09:30:57.227 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Sending streaming pull request for projects/first-strength-448400-n4/subscriptions/home-assistant-ftgOCd1bFZ
2025-03-21 09:30:57.433 DEBUG (MainThread) [google_nest_sdm.streaming_manager] Event stream connection established
2025-03-21 09:30:57.433 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Starting streaming iterator
2025-03-21 09:30:57.434 DEBUG (MainThread) [google_nest_sdm.auth] request[get]=https://smartdevicemanagement.googleapis.com/v1/enterprises/c141e887-5c5c-4922-9a34-14facc47c7c3/structures
2025-03-21 09:30:57.434 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Sending streaming pull request (acking 0 messages)
2025-03-21 09:30:57.752 DEBUG (MainThread) [google_nest_sdm.auth] response={'structures': [{'name': 'enterprises/c141e887-5c5c-4922-9a34-14facc47c7c3/structures/AVPHwEvGertwxzkXY23_7_4tIW2gkPgBonQQK71LZTbRZ5AN6g-zhpUMnYVtmcRkAUs79KV6vz-ifTxV849HxH0urFLdSQ', 'traits': {'sdm.structures.traits.Info': {'customName': 'Home'}}}]}
2025-03-21 09:30:57.752 DEBUG (MainThread) [google_nest_sdm.auth] request[get]=https://smartdevicemanagement.googleapis.com/v1/enterprises/c141e887-5c5c-4922-9a34-14facc47c7c3/devices
2025-03-21 09:30:58.641 DEBUG (MainThread) [google_nest_sdm.auth] response={'devices': [{'name': 'enterprises/c141e887-5c5c-4922-9a34-14facc47c7c3/devices/AVPHwEvJ1Oa83Zo38tN_cWsomCAO09is-EGvjWvOBGIfp_JUInirlYVHmXOlvbtlfJFmOXsnDOAj7a2Degba5vZpvJ7ajg', 'type': 'sdm.devices.types.THERMOSTAT', 'assignee': 'enterprises/c141e887-5c5c-4922-9a34-14facc47c7c3/structures/AVPHwEvGertwxzkXY23_7_4tIW2gkPgBonQQK71LZTbRZ5AN6g-zhpUMnYVtmcRkAUs79KV6vz-ifTxV849HxH0urFLdSQ/rooms/AVPHwEvBKpyZTdZ-kCxheWpOQEgZM-KHQNwfE0Dn_n6GJGXLl3WttEIcLiSmCg2BozzLKa1j12AD3GrUXfuix15hX6S2wrJM-7xjwdwrA2k_-u2J6-cuE7mYrQori588dX5tJT800Rcsug8', 'traits': {'sdm.devices.traits.Info': {'customName': ''}, 'sdm.devices.traits.Humidity': {'ambientHumidityPercent': 41}, 'sdm.devices.traits.Connectivity': {'status': 'ONLINE'}, 'sdm.devices.traits.Fan': {}, 'sdm.devices.traits.ThermostatMode': {'mode': 'HEAT', 'availableModes': ['HEAT', 'OFF']}, 'sdm.devices.traits.ThermostatEco': {'availableModes': ['OFF', 'MANUAL_ECO'], 'mode': 'OFF', 'heatCelsius': 10, 'coolCelsius': 24.444443}, 'sdm.devices.traits.ThermostatHvac': {'status': 'OFF'}, 'sdm.devices.traits.Settings': {'temperatureScale': 'FAHRENHEIT'}, 'sdm.devices.traits.ThermostatTemperatureSetpoint': {'heatCelsius': 18.075455}, 'sdm.devices.traits.Temperature': {'ambientTemperatureCelsius': 19.789993}}, 'parentRelations': [{'parent': 'enterprises/c141e887-5c5c-4922-9a34-14facc47c7c3/structures/AVPHwEvGertwxzkXY23_7_4tIW2gkPgBonQQK71LZTbRZ5AN6g-zhpUMnYVtmcRkAUs79KV6vz-ifTxV849HxH0urFLdSQ/rooms/AVPHwEvBKpyZTdZ-kCxheWpOQEgZM-KHQNwfE0Dn_n6GJGXLl3WttEIcLiSmCg2BozzLKa1j12AD3GrUXfuix15hX6S2wrJM-7xjwdwrA2k_-u2J6-cuE7mYrQori588dX5tJT800Rcsug8', 'displayName': 'Second Floor'}]}, {'name': 'enterprises/c141e887-5c5c-4922-9a34-14facc47c7c3/devices/AVPHwEssWGaO42GB5EPgKtXU_sDtfZI6-_-wEybxm-J-WgP2oTaR4mAyj51trvvVlB3VIHiK63dj6iTehU4KwcQU6mTqxQ', 'type': 'sdm.devices.types.THERMOSTAT', 'assignee': 'enterprises/c141e887-5c5c-4922-9a34-14facc47c7c3/structures/AVPHwEvGertwxzkXY23_7_4tIW2gkPgBonQQK71LZTbRZ5AN6g-zhpUMnYVtmcRkAUs79KV6vz-ifTxV849HxH0urFLdSQ/rooms/AVPHwEuVMbRKXl4mD_FyOWN13y9YUKUttg9qrY_XvCCBQvaFyqOGnYtky_u2IhL63c2CK2S3hwxb9gV7FrOER73oxEC94YUPTFu5MMQS3-dQwnfQxW2ODGrHObAvF_z-9XvPNADLeI1ruoA', 'traits': {'sdm.devices.traits.Info': {'customName': ''}, 'sdm.devices.traits.Humidity': {'ambientHumidityPercent': 46}, 'sdm.devices.traits.Connectivity': {'status': 'ONLINE'}, 'sdm.devices.traits.Fan': {'timerMode': 'OFF'}, 'sdm.devices.traits.ThermostatMode': {'mode': 'OFF', 'availableModes': ['COOL', 'OFF']}, 'sdm.devices.traits.ThermostatEco': {'availableModes': ['OFF', 'MANUAL_ECO'], 'mode': 'OFF', 'heatCelsius': 4.4444427, 'coolCelsius': 25.73265}, 'sdm.devices.traits.ThermostatHvac': {'status': 'OFF'}, 'sdm.devices.traits.Settings': {'temperatureScale': 'FAHRENHEIT'}, 'sdm.devices.traits.ThermostatTemperatureSetpoint': {}, 'sdm.devices.traits.Temperature': {'ambientTemperatureCelsius': 20.789993}}, 'parentRelations': [{'parent': 'enterprises/c141e887-5c5c-4922-9a34-14facc47c7c3/structures/AVPHwEvGertwxzkXY23_7_4tIW2gkPgBonQQK71LZTbRZ5AN6g-zhpUMnYVtmcRkAUs79KV6vz-ifTxV849HxH0urFLdSQ/rooms/AVPHwEuVMbRKXl4mD_FyOWN13y9YUKUttg9qrY_XvCCBQvaFyqOGnYtky_u2IhL63c2CK2S3hwxb9gV7FrOER73oxEC94YUPTFu5MMQS3-dQwnfQxW2ODGrHObAvF_z-9XvPNADLeI1ruoA', 'displayName': 'Air Con'}]}, {'name': 'enterprises/c141e887-5c5c-4922-9a34-14facc47c7c3/devices/AVPHwEtCXHJN0mr8OTWJMkZ2JFbYPGjX23x3nJknn4RvLo5cm6GYT4sGwgof1v6jx3MRxCtc7wjapNRnMmqIdXkopH2hmg', 'type': 'sdm.devices.types.THERMOSTAT', 'assignee': 'enterprises/c141e887-5c5c-4922-9a34-14facc47c7c3/structures/AVPHwEvGertwxzkXY23_7_4tIW2gkPgBonQQK71LZTbRZ5AN6g-zhpUMnYVtmcRkAUs79KV6vz-ifTxV849HxH0urFLdSQ/rooms/AVPHwEun3HDD8EZclvwWHDPoc7b1zTYrF_ZeBoDehxFc2TsJFkvLyYiU4Y_XZO1PNDEzwknRjEsZkUna32-qksFvZLfuw8IsGELHRMJCCu7ei8glCVzlcvl4fKmkboOEMQGfzmU3z1HjCEk', 'traits': {'sdm.devices.traits.Info': {'customName': ''}, 'sdm.devices.traits.Humidity': {'ambientHumidityPercent': 44}, 'sdm.devices.traits.Connectivity': {'status': 'ONLINE'}, 'sdm.devices.traits.Fan': {}, 'sdm.devices.traits.ThermostatMode': {'mode': 'HEAT', 'availableModes': ['HEAT', 'OFF']}, 'sdm.devices.traits.ThermostatEco': {'availableModes': ['OFF', 'MANUAL_ECO'], 'mode': 'OFF', 'heatCelsius': 10, 'coolCelsius': 24.444443}, 'sdm.devices.traits.ThermostatHvac': {'status': 'OFF'}, 'sdm.devices.traits.Settings': {'temperatureScale': 'FAHRENHEIT'}, 'sdm.devices.traits.ThermostatTemperatureSetpoint': {'heatCelsius': 17.667831}, 'sdm.devices.traits.Temperature': {'ambientTemperatureCelsius': 18.019989}}, 'parentRelations': [{'parent': 'enterprises/c141e887-5c5c-4922-9a34-14facc47c7c3/structures/AVPHwEvGertwxzkXY23_7_4tIW2gkPgBonQQK71LZTbRZ5AN6g-zhpUMnYVtmcRkAUs79KV6vz-ifTxV849HxH0urFLdSQ/rooms/AVPHwEun3HDD8EZclvwWHDPoc7b1zTYrF_ZeBoDehxFc2TsJFkvLyYiU4Y_XZO1PNDEzwknRjEsZkUna32-qksFvZLfuw8IsGELHRMJCCu7ei8glCVzlcvl4fKmkboOEMQGfzmU3z1HjCEk', 'displayName': 'Basement'}]}, {'name': 'enterprises/c141e887-5c5c-4922-9a34-14facc47c7c3/devices/AVPHwEtagKfxkGCoPtBW7Mx4A_7vqy8Oihak4_7zMZQJ42WJbeNzIhUCAp0qpmHjXCR5y-5DrfyPDiiD79VTqG32uy5LtA', 'type': 'sdm.devices.types.THERMOSTAT', 'assignee': 'enterprises/c141e887-5c5c-4922-9a34-14facc47c7c3/structures/AVPHwEvGertwxzkXY23_7_4tIW2gkPgBonQQK71LZTbRZ5AN6g-zhpUMnYVtmcRkAUs79KV6vz-ifTxV849HxH0urFLdSQ/rooms/AVPHwEsrZZGLMCyvDc7DQVReYq4okf_uiG8k1RbNbz2lHU4JRN_2NrATcLVto0bJjoDFH590TqxtH5V4RpkqgBuvPAGJ5tvtee0irm50q5X0U1gt7SwOA_vgQuXC0MaKP_1yAVleDB0wK0g', 'traits': {'sdm.devices.traits.Info': {'customName': ''}, 'sdm.devices.traits.Humidity': {'ambientHumidityPercent': 32}, 'sdm.devices.traits.Connectivity': {'status': 'ONLINE'}, 'sdm.devices.traits.Fan': {}, 'sdm.devices.traits.ThermostatMode': {'mode': 'HEAT', 'availableModes': ['HEAT', 'OFF']}, 'sdm.devices.traits.ThermostatEco': {'availableModes': ['OFF', 'MANUAL_ECO'], 'mode': 'OFF', 'heatCelsius': 10, 'coolCelsius': 24.444443}, 'sdm.devices.traits.ThermostatHvac': {'status': 'OFF'}, 'sdm.devices.traits.Settings': {'temperatureScale': 'FAHRENHEIT'}, 'sdm.devices.traits.ThermostatTemperatureSetpoint': {'heatCelsius': 20}, 'sdm.devices.traits.Temperature': {'ambientTemperatureCelsius': 20.339996}}, 'parentRelations': [{'parent': 'enterprises/c141e887-5c5c-4922-9a34-14facc47c7c3/structures/AVPHwEvGertwxzkXY23_7_4tIW2gkPgBonQQK71LZTbRZ5AN6g-zhpUMnYVtmcRkAUs79KV6vz-ifTxV849HxH0urFLdSQ/rooms/AVPHwEsrZZGLMCyvDc7DQVReYq4okf_uiG8k1RbNbz2lHU4JRN_2NrATcLVto0bJjoDFH590TqxtH5V4RpkqgBuvPAGJ5tvtee0irm50q5X0U1gt7SwOA_vgQuXC0MaKP_1yAVleDB0wK0g', 'displayName': 'First floor'}]}]}
2025-03-21 09:31:30.275 WARNING (MainThread) [homeassistant.components.homekit_controller.connection] HomeKit device no longer detecting back pressure - not skipping poll: 44:B7:7F:14:F5:12
2025-03-21 09:31:34.188 WARNING (MainThread) [homeassistant.components.homekit_controller.connection] HomeKit device update skipped as previous poll still in flight: 44:B7:7F:14:F5:12
2025-03-21 09:31:49.778 DEBUG (MainThread) [google_nest_sdm.streaming_manager] Stopping subscription projects/first-strength-448400-n4/subscriptions/home-assistant-ftgOCd1bFZ
2025-03-21 09:31:49.783 DEBUG (MainThread) [google_nest_sdm.streaming_manager] Subscription loop cancelled
2025-03-21 09:31:49.786 DEBUG (MainThread) [google_nest_sdm.google_nest_subscriber] Starting subscription projects/first-strength-448400-n4/subscriptions/home-assistant-ftgOCd1bFZ
2025-03-21 09:31:49.786 DEBUG (MainThread) [google_nest_sdm.streaming_manager] Connecting with streaming pull
2025-03-21 09:31:49.786 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Credentials refreshed, new expiry 2025-03-21 10:25:47.986864
2025-03-21 09:31:49.789 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Sending streaming pull request for projects/first-strength-448400-n4/subscriptions/home-assistant-ftgOCd1bFZ
2025-03-21 09:31:49.976 DEBUG (MainThread) [google_nest_sdm.streaming_manager] Event stream connection established
2025-03-21 09:31:49.976 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Starting streaming iterator
2025-03-21 09:31:49.976 DEBUG (MainThread) [google_nest_sdm.auth] request[get]=https://smartdevicemanagement.googleapis.com/v1/enterprises/c141e887-5c5c-4922-9a34-14facc47c7c3/structures
2025-03-21 09:31:49.978 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Sending streaming pull request (acking 0 messages)
2025-03-21 09:31:50.268 DEBUG (MainThread) [google_nest_sdm.auth] response={'structures': [{'name': 'enterprises/c141e887-5c5c-4922-9a34-14facc47c7c3/structures/AVPHwEvGertwxzkXY23_7_4tIW2gkPgBonQQK71LZTbRZ5AN6g-zhpUMnYVtmcRkAUs79KV6vz-ifTxV849HxH0urFLdSQ', 'traits': {'sdm.structures.traits.Info': {'customName': 'Home'}}}]}
2025-03-21 09:31:50.268 DEBUG (MainThread) [google_nest_sdm.auth] request[get]=https://smartdevicemanagement.googleapis.com/v1/enterprises/c141e887-5c5c-4922-9a34-14facc47c7c3/devices
2025-03-21 09:31:51.000 DEBUG (MainThread) [google_nest_sdm.auth] response={'devices': [{'name': 'enterprises/c141e887-5c5c-4922-9a34-14facc47c7c3/devices/AVPHwEvJ1Oa83Zo38tN_cWsomCAO09is-EGvjWvOBGIfp_JUInirlYVHmXOlvbtlfJFmOXsnDOAj7a2Degba5vZpvJ7ajg', 'type': 'sdm.devices.types.THERMOSTAT', 'assignee': 'enterprises/c141e887-5c5c-4922-9a34-14facc47c7c3/structures/AVPHwEvGertwxzkXY23_7_4tIW2gkPgBonQQK71LZTbRZ5AN6g-zhpUMnYVtmcRkAUs79KV6vz-ifTxV849HxH0urFLdSQ/rooms/AVPHwEvBKpyZTdZ-kCxheWpOQEgZM-KHQNwfE0Dn_n6GJGXLl3WttEIcLiSmCg2BozzLKa1j12AD3GrUXfuix15hX6S2wrJM-7xjwdwrA2k_-u2J6-cuE7mYrQori588dX5tJT800Rcsug8', 'traits': {'sdm.devices.traits.Info': {'customName': ''}, 'sdm.devices.traits.Humidity': {'ambientHumidityPercent': 41}, 'sdm.devices.traits.Connectivity': {'status': 'ONLINE'}, 'sdm.devices.traits.Fan': {}, 'sdm.devices.traits.ThermostatMode': {'mode': 'HEAT', 'availableModes': ['HEAT', 'OFF']}, 'sdm.devices.traits.ThermostatEco': {'availableModes': ['OFF', 'MANUAL_ECO'], 'mode': 'OFF', 'heatCelsius': 10, 'coolCelsius': 24.444443}, 'sdm.devices.traits.ThermostatHvac': {'status': 'OFF'}, 'sdm.devices.traits.Settings': {'temperatureScale': 'FAHRENHEIT'}, 'sdm.devices.traits.ThermostatTemperatureSetpoint': {'heatCelsius': 18.075455}, 'sdm.devices.traits.Temperature': {'ambientTemperatureCelsius': 19.789993}}, 'parentRelations': [{'parent': 'enterprises/c141e887-5c5c-4922-9a34-14facc47c7c3/structures/AVPHwEvGertwxzkXY23_7_4tIW2gkPgBonQQK71LZTbRZ5AN6g-zhpUMnYVtmcRkAUs79KV6vz-ifTxV849HxH0urFLdSQ/rooms/AVPHwEvBKpyZTdZ-kCxheWpOQEgZM-KHQNwfE0Dn_n6GJGXLl3WttEIcLiSmCg2BozzLKa1j12AD3GrUXfuix15hX6S2wrJM-7xjwdwrA2k_-u2J6-cuE7mYrQori588dX5tJT800Rcsug8', 'displayName': 'Second Floor'}]}, {'name': 'enterprises/c141e887-5c5c-4922-9a34-14facc47c7c3/devices/AVPHwEssWGaO42GB5EPgKtXU_sDtfZI6-_-wEybxm-J-WgP2oTaR4mAyj51trvvVlB3VIHiK63dj6iTehU4KwcQU6mTqxQ', 'type': 'sdm.devices.types.THERMOSTAT', 'assignee': 'enterprises/c141e887-5c5c-4922-9a34-14facc47c7c3/structures/AVPHwEvGertwxzkXY23_7_4tIW2gkPgBonQQK71LZTbRZ5AN6g-zhpUMnYVtmcRkAUs79KV6vz-ifTxV849HxH0urFLdSQ/rooms/AVPHwEuVMbRKXl4mD_FyOWN13y9YUKUttg9qrY_XvCCBQvaFyqOGnYtky_u2IhL63c2CK2S3hwxb9gV7FrOER73oxEC94YUPTFu5MMQS3-dQwnfQxW2ODGrHObAvF_z-9XvPNADLeI1ruoA', 'traits': {'sdm.devices.traits.Info': {'customName': ''}, 'sdm.devices.traits.Humidity': {'ambientHumidityPercent': 46}, 'sdm.devices.traits.Connectivity': {'status': 'ONLINE'}, 'sdm.devices.traits.Fan': {'timerMode': 'OFF'}, 'sdm.devices.traits.ThermostatMode': {'mode': 'OFF', 'availableModes': ['COOL', 'OFF']}, 'sdm.devices.traits.ThermostatEco': {'availableModes': ['OFF', 'MANUAL_ECO'], 'mode': 'OFF', 'heatCelsius': 4.4444427, 'coolCelsius': 25.73265}, 'sdm.devices.traits.ThermostatHvac': {'status': 'OFF'}, 'sdm.devices.traits.Settings': {'temperatureScale': 'FAHRENHEIT'}, 'sdm.devices.traits.ThermostatTemperatureSetpoint': {}, 'sdm.devices.traits.Temperature': {'ambientTemperatureCelsius': 20.789993}}, 'parentRelations': [{'parent': 'enterprises/c141e887-5c5c-4922-9a34-14facc47c7c3/structures/AVPHwEvGertwxzkXY23_7_4tIW2gkPgBonQQK71LZTbRZ5AN6g-zhpUMnYVtmcRkAUs79KV6vz-ifTxV849HxH0urFLdSQ/rooms/AVPHwEuVMbRKXl4mD_FyOWN13y9YUKUttg9qrY_XvCCBQvaFyqOGnYtky_u2IhL63c2CK2S3hwxb9gV7FrOER73oxEC94YUPTFu5MMQS3-dQwnfQxW2ODGrHObAvF_z-9XvPNADLeI1ruoA', 'displayName': 'Air Con'}]}, {'name': 'enterprises/c141e887-5c5c-4922-9a34-14facc47c7c3/devices/AVPHwEtCXHJN0mr8OTWJMkZ2JFbYPGjX23x3nJknn4RvLo5cm6GYT4sGwgof1v6jx3MRxCtc7wjapNRnMmqIdXkopH2hmg', 'type': 'sdm.devices.types.THERMOSTAT', 'assignee': 'enterprises/c141e887-5c5c-4922-9a34-14facc47c7c3/structures/AVPHwEvGertwxzkXY23_7_4tIW2gkPgBonQQK71LZTbRZ5AN6g-zhpUMnYVtmcRkAUs79KV6vz-ifTxV849HxH0urFLdSQ/rooms/AVPHwEun3HDD8EZclvwWHDPoc7b1zTYrF_ZeBoDehxFc2TsJFkvLyYiU4Y_XZO1PNDEzwknRjEsZkUna32-qksFvZLfuw8IsGELHRMJCCu7ei8glCVzlcvl4fKmkboOEMQGfzmU3z1HjCEk', 'traits': {'sdm.devices.traits.Info': {'customName': ''}, 'sdm.devices.traits.Humidity': {'ambientHumidityPercent': 44}, 'sdm.devices.traits.Connectivity': {'status': 'ONLINE'}, 'sdm.devices.traits.Fan': {}, 'sdm.devices.traits.ThermostatMode': {'mode': 'HEAT', 'availableModes': ['HEAT', 'OFF']}, 'sdm.devices.traits.ThermostatEco': {'availableModes': ['OFF', 'MANUAL_ECO'], 'mode': 'OFF', 'heatCelsius': 10, 'coolCelsius': 24.444443}, 'sdm.devices.traits.ThermostatHvac': {'status': 'OFF'}, 'sdm.devices.traits.Settings': {'temperatureScale': 'FAHRENHEIT'}, 'sdm.devices.traits.ThermostatTemperatureSetpoint': {'heatCelsius': 17.667831}, 'sdm.devices.traits.Temperature': {'ambientTemperatureCelsius': 18.019989}}, 'parentRelations': [{'parent': 'enterprises/c141e887-5c5c-4922-9a34-14facc47c7c3/structures/AVPHwEvGertwxzkXY23_7_4tIW2gkPgBonQQK71LZTbRZ5AN6g-zhpUMnYVtmcRkAUs79KV6vz-ifTxV849HxH0urFLdSQ/rooms/AVPHwEun3HDD8EZclvwWHDPoc7b1zTYrF_ZeBoDehxFc2TsJFkvLyYiU4Y_XZO1PNDEzwknRjEsZkUna32-qksFvZLfuw8IsGELHRMJCCu7ei8glCVzlcvl4fKmkboOEMQGfzmU3z1HjCEk', 'displayName': 'Basement'}]}, {'name': 'enterprises/c141e887-5c5c-4922-9a34-14facc47c7c3/devices/AVPHwEtagKfxkGCoPtBW7Mx4A_7vqy8Oihak4_7zMZQJ42WJbeNzIhUCAp0qpmHjXCR5y-5DrfyPDiiD79VTqG32uy5LtA', 'type': 'sdm.devices.types.THERMOSTAT', 'assignee': 'enterprises/c141e887-5c5c-4922-9a34-14facc47c7c3/structures/AVPHwEvGertwxzkXY23_7_4tIW2gkPgBonQQK71LZTbRZ5AN6g-zhpUMnYVtmcRkAUs79KV6vz-ifTxV849HxH0urFLdSQ/rooms/AVPHwEsrZZGLMCyvDc7DQVReYq4okf_uiG8k1RbNbz2lHU4JRN_2NrATcLVto0bJjoDFH590TqxtH5V4RpkqgBuvPAGJ5tvtee0irm50q5X0U1gt7SwOA_vgQuXC0MaKP_1yAVleDB0wK0g', 'traits': {'sdm.devices.traits.Info': {'customName': ''}, 'sdm.devices.traits.Humidity': {'ambientHumidityPercent': 32}, 'sdm.devices.traits.Connectivity': {'status': 'ONLINE'}, 'sdm.devices.traits.Fan': {}, 'sdm.devices.traits.ThermostatMode': {'mode': 'HEAT', 'availableModes': ['HEAT', 'OFF']}, 'sdm.devices.traits.ThermostatEco': {'availableModes': ['OFF', 'MANUAL_ECO'], 'mode': 'OFF', 'heatCelsius': 10, 'coolCelsius': 24.444443}, 'sdm.devices.traits.ThermostatHvac': {'status': 'OFF'}, 'sdm.devices.traits.Settings': {'temperatureScale': 'FAHRENHEIT'}, 'sdm.devices.traits.ThermostatTemperatureSetpoint': {'heatCelsius': 20}, 'sdm.devices.traits.Temperature': {'ambientTemperatureCelsius': 20.339996}}, 'parentRelations': [{'parent': 'enterprises/c141e887-5c5c-4922-9a34-14facc47c7c3/structures/AVPHwEvGertwxzkXY23_7_4tIW2gkPgBonQQK71LZTbRZ5AN6g-zhpUMnYVtmcRkAUs79KV6vz-ifTxV849HxH0urFLdSQ/rooms/AVPHwEsrZZGLMCyvDc7DQVReYq4okf_uiG8k1RbNbz2lHU4JRN_2NrATcLVto0bJjoDFH590TqxtH5V4RpkqgBuvPAGJ5tvtee0irm50q5X0U1gt7SwOA_vgQuXC0MaKP_1yAVleDB0wK0g', 'displayName': 'First floor'}]}]}
2025-03-21 09:33:19.979 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Sending streaming pull request (acking 0 messages)
2025-03-21 09:34:22.077 DEBUG (MainThread) [google_nest_sdm.subscriber_client] API error in streaming pull: 503 The service was unable to fulfill your request. Please try again. [code=8a75]
2025-03-21 09:34:22.078 DEBUG (MainThread) [google_nest_sdm.streaming_manager] Disconnected from event stream: API error when streaming iterator: 503 The service was unable to fulfill your request. Please try again. [code=8a75]
2025-03-21 09:34:22.079 DEBUG (MainThread) [google_nest_sdm.streaming_manager] Reconnecting stream in 10.0 seconds
2025-03-21 09:34:32.080 DEBUG (MainThread) [google_nest_sdm.streaming_manager] Connecting with streaming pull
2025-03-21 09:34:32.081 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Credentials refreshed, new expiry 2025-03-21 10:25:47.986864
2025-03-21 09:34:32.083 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Sending streaming pull request for projects/first-strength-448400-n4/subscriptions/home-assistant-ftgOCd1bFZ
2025-03-21 09:34:32.285 DEBUG (MainThread) [google_nest_sdm.streaming_manager] Event stream connection established
2025-03-21 09:34:32.285 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Starting streaming iterator
2025-03-21 09:34:32.286 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Sending streaming pull request (acking 0 messages)
2025-03-21 09:34:49.981 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Sending streaming pull request (acking 0 messages)
2025-03-21 09:35:51.730 DEBUG (MainThread) [google_nest_sdm.subscriber_client] API error in streaming pull: 503 The service was unable to fulfill your request. Please try again. [code=8a75]
2025-03-21 09:35:51.731 DEBUG (MainThread) [google_nest_sdm.streaming_manager] Disconnected from event stream: API error when streaming iterator: 503 The service was unable to fulfill your request. Please try again. [code=8a75]
2025-03-21 09:35:51.731 DEBUG (MainThread) [google_nest_sdm.streaming_manager] Reconnecting stream in 10.0 seconds
2025-03-21 09:36:01.732 DEBUG (MainThread) [google_nest_sdm.streaming_manager] Connecting with streaming pull
2025-03-21 09:36:01.733 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Credentials refreshed, new expiry 2025-03-21 10:25:47.986864
2025-03-21 09:36:01.735 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Sending streaming pull request for projects/first-strength-448400-n4/subscriptions/home-assistant-ftgOCd1bFZ
2025-03-21 09:36:01.925 DEBUG (MainThread) [google_nest_sdm.streaming_manager] Event stream connection established
2025-03-21 09:36:01.925 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Starting streaming iterator
2025-03-21 09:36:01.926 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Sending streaming pull request (acking 0 messages)
2025-03-21 09:36:02.286 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Sending streaming pull request (acking 0 messages)
2025-03-21 09:36:30.275 WARNING (MainThread) [homeassistant.components.homekit_controller.connection] HomeKit device no longer detecting back pressure - not skipping poll: 44:B7:7F:14:F5:12
2025-03-21 09:36:33.943 WARNING (MainThread) [homeassistant.components.homekit_controller.connection] HomeKit device update skipped as previous poll still in flight: 44:B7:7F:14:F5:12
2025-03-21 09:37:31.927 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Sending streaming pull request (acking 0 messages)
2025-03-21 09:38:55.833 DEBUG (MainThread) [google_nest_sdm.subscriber_client] API error in streaming pull: 503 The service was unable to fulfill your request. Please try again. [code=8a75]
2025-03-21 09:38:55.833 DEBUG (MainThread) [google_nest_sdm.streaming_manager] Disconnected from event stream: API error when streaming iterator: 503 The service was unable to fulfill your request. Please try again. [code=8a75]
2025-03-21 09:38:55.833 DEBUG (MainThread) [google_nest_sdm.streaming_manager] Reconnecting stream in 10.0 seconds
2025-03-21 09:39:01.929 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Sending streaming pull request (acking 0 messages)
2025-03-21 09:39:05.834 DEBUG (MainThread) [google_nest_sdm.streaming_manager] Connecting with streaming pull
2025-03-21 09:39:05.834 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Credentials refreshed, new expiry 2025-03-21 10:25:47.986864
2025-03-21 09:39:05.838 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Sending streaming pull request for projects/first-strength-448400-n4/subscriptions/home-assistant-ftgOCd1bFZ
2025-03-21 09:39:06.030 DEBUG (MainThread) [google_nest_sdm.streaming_manager] Event stream connection established
2025-03-21 09:39:06.031 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Starting streaming iterator
2025-03-21 09:39:06.031 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Sending streaming pull request (acking 0 messages)
2025-03-21 09:40:36.032 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Sending streaming pull request (acking 0 messages)
2025-03-21 09:41:21.322 DEBUG (MainThread) [google_nest_sdm.auth] request[post]=https://smartdevicemanagement.googleapis.com/v1/enterprises/c141e887-5c5c-4922-9a34-14facc47c7c3/devices/AVPHwEvJ1Oa83Zo38tN_cWsomCAO09is-EGvjWvOBGIfp_JUInirlYVHmXOlvbtlfJFmOXsnDOAj7a2Degba5vZpvJ7ajg:executeCommand
2025-03-21 09:41:21.322 DEBUG (MainThread) [google_nest_sdm.auth] request[post json]={'command': 'sdm.devices.commands.ThermostatTemperatureSetpoint.SetHeat', 'params': {'heatCelsius': 21.11111111111111}}
2025-03-21 09:41:28.927 DEBUG (MainThread) [google_nest_sdm.auth] request[post]=https://smartdevicemanagement.googleapis.com/v1/enterprises/c141e887-5c5c-4922-9a34-14facc47c7c3/devices/AVPHwEvJ1Oa83Zo38tN_cWsomCAO09is-EGvjWvOBGIfp_JUInirlYVHmXOlvbtlfJFmOXsnDOAj7a2Degba5vZpvJ7ajg:executeCommand
2025-03-21 09:41:28.927 DEBUG (MainThread) [google_nest_sdm.auth] request[post json]={'command': 'sdm.devices.commands.ThermostatTemperatureSetpoint.SetHeat', 'params': {'heatCelsius': 20.0}}
2025-03-21 09:41:30.275 WARNING (MainThread) [homeassistant.components.homekit_controller.connection] HomeKit device no longer detecting back pressure - not skipping poll: 44:B7:7F:14:F5:12
2025-03-21 09:41:33.326 WARNING (MainThread) [homeassistant.components.homekit_controller.connection] HomeKit device update skipped as previous poll still in flight: 44:B7:7F:14:F5:12
2025-03-21 09:42:02.959 DEBUG (MainThread) [google_nest_sdm.subscriber_client] API error in streaming pull: 503 The service was unable to fulfill your request. Please try again. [code=8a75]
2025-03-21 09:42:02.959 DEBUG (MainThread) [google_nest_sdm.streaming_manager] Disconnected from event stream: API error when streaming iterator: 503 The service was unable to fulfill your request. Please try again. [code=8a75]
2025-03-21 09:42:02.960 DEBUG (MainThread) [google_nest_sdm.streaming_manager] Reconnecting stream in 10.0 seconds
2025-03-21 09:42:06.035 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Sending streaming pull request (acking 0 messages)
2025-03-21 09:42:12.961 DEBUG (MainThread) [google_nest_sdm.streaming_manager] Connecting with streaming pull
2025-03-21 09:42:12.961 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Credentials refreshed, new expiry 2025-03-21 10:25:47.986864
2025-03-21 09:42:12.965 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Sending streaming pull request for projects/first-strength-448400-n4/subscriptions/home-assistant-ftgOCd1bFZ
2025-03-21 09:42:13.142 DEBUG (MainThread) [google_nest_sdm.streaming_manager] Event stream connection established
2025-03-21 09:42:13.142 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Starting streaming iterator
2025-03-21 09:42:13.143 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Sending streaming pull request (acking 0 messages)
2025-03-21 09:43:38.521 DEBUG (MainThread) [google_nest_sdm.subscriber_client] API error in streaming pull: 503 The service was unable to fulfill your request. Please try again. [code=8a75]
2025-03-21 09:43:38.521 DEBUG (MainThread) [google_nest_sdm.streaming_manager] Disconnected from event stream: API error when streaming iterator: 503 The service was unable to fulfill your request. Please try again. [code=8a75]
2025-03-21 09:43:38.521 DEBUG (MainThread) [google_nest_sdm.streaming_manager] Reconnecting stream in 10.0 seconds
2025-03-21 09:43:43.146 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Sending streaming pull request (acking 0 messages)
2025-03-21 09:43:48.522 DEBUG (MainThread) [google_nest_sdm.streaming_manager] Connecting with streaming pull
2025-03-21 09:43:48.522 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Credentials refreshed, new expiry 2025-03-21 10:25:47.986864
2025-03-21 09:43:48.525 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Sending streaming pull request for projects/first-strength-448400-n4/subscriptions/home-assistant-ftgOCd1bFZ
2025-03-21 09:43:48.698 DEBUG (MainThread) [google_nest_sdm.streaming_manager] Event stream connection established
2025-03-21 09:43:48.698 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Starting streaming iterator
2025-03-21 09:43:48.699 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Sending streaming pull request (acking 0 messages)
2025-03-21 09:45:17.787 DEBUG (MainThread) [google_nest_sdm.subscriber_client] API error in streaming pull: 503 The service was unable to fulfill your request. Please try again. [code=8a75]
2025-03-21 09:45:17.787 DEBUG (MainThread) [google_nest_sdm.streaming_manager] Disconnected from event stream: API error when streaming iterator: 503 The service was unable to fulfill your request. Please try again. [code=8a75]
2025-03-21 09:45:17.787 DEBUG (MainThread) [google_nest_sdm.streaming_manager] Reconnecting stream in 10.0 seconds
2025-03-21 09:45:18.700 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Sending streaming pull request (acking 0 messages)
2025-03-21 09:45:27.788 DEBUG (MainThread) [google_nest_sdm.streaming_manager] Connecting with streaming pull
2025-03-21 09:45:27.788 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Credentials refreshed, new expiry 2025-03-21 10:25:47.986864
2025-03-21 09:45:27.791 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Sending streaming pull request for projects/first-strength-448400-n4/subscriptions/home-assistant-ftgOCd1bFZ
2025-03-21 09:45:27.955 DEBUG (MainThread) [google_nest_sdm.streaming_manager] Event stream connection established
2025-03-21 09:45:27.955 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Starting streaming iterator
2025-03-21 09:45:27.956 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Sending streaming pull request (acking 0 messages)
2025-03-21 09:46:30.277 WARNING (MainThread) [homeassistant.components.homekit_controller.connection] HomeKit device no longer detecting back pressure - not skipping poll: 44:B7:7F:14:F5:12
2025-03-21 09:46:46.110 WARNING (MainThread) [homeassistant.components.homekit_controller.connection] HomeKit device update skipped as previous poll still in flight: 44:B7:7F:14:F5:12
2025-03-21 09:46:57.958 DEBUG (MainThread) [google_nest_sdm.subscriber_client] Sending streaming pull request (acking 0 messages)
Ok, I did a complete reinstall (regaulr pi with m2, as opposed to dev kit with m2 as part of it)), and I am not 100% sure that the pub sub config as part of the auth process took last time - a new install with the old auth worked - I installed the integration, clicked dialog prompting about setting up authentication, 10-15 minutes later it let me start config (would only nag about doing the auth until that point)
