Hey HA friends! ![]()
I think there was something similar already created when I just looked it briefly, but I wanted to explore it further and created my first addon to HA.
So basically, I’m a Google fan and I use google assistant in my home for some stuff, one that I use often is to add items to my shopping list. But with HA and have automated notification for when I am in the store etc to grab the list of stuff that I need to buy, and to share with family, I needed something that keep takes the items from my google and sync it with my HA setup.
So I created a simple addon that syncs (one way) from shopping list to the HA shopping list! ![]()
What It Does
Reads your Google Keep shopping list (the one Google Assistant writes to)
Grabs any unchecked items
Adds them to Home Assistant’s native shopping_list
Marks them as checked in Keep so you don’t get duplicates
Runs every few minutes in the background and just works.
What You Need
- Your Google email + password
(used securely viagkeepapi, no OAuth or app password — just like the official Keep Android app)
** This is more tricky, because you need a “master_password” you can read more how you can get one in the README of the project - A working Home Assistant setup
- A long-lived access token from HA (for calling the shopping list API)
How to Use
- Install the addon via your Home Assistant addon page. Add the repository: GitHub - joshlopes/monomagic: Bucket for all my magic
- Select the Google Keep Sync addon and Install (This will build the docker image)
- Once installed configure your email, password, HA URL, and HA token in the addon config UI
- Start the addon
- Done. It syncs every 5 minutes by default (you can change that too)
No .env, no hacking, no Google Workspace required — works with your regular Gmail and Google Assistant – But you will need this “master_password” which is a bit annoying to get it, but also not that complex!
Under the Hood
- Powered by
gkeepapi(Python) - Uses Docker, comes with
Dockerfile - Simple, readable, and easy to tweak
Again apologies if I re-invented the wheel but needed this for a while – are you using something similar? Let me know please as it might be even better than this and I am happy to replace my setup by anything that is easier than the above ![]()
If you liked or have few suggestions, let me know and I can make this even better for everyone ![]()
EDIT: Screenshot of it running
Cheers!
