I assume this is due somehow to the changes with device_tracker. Can anyone confirm or explain how I can reconfigure this to get it back working again? Here are my details:
The new device tracker has an “_2” appended to the name as expected and its working fine:
Here is my config that no longer works with HA 0.94:
- platform: google_travel_time
api_key: !secret google_api
origin: device_tracker.831cbb44_2
destination: zone.home
scan_interval: 600
With the config above, the time_from_home sensor is never created. Instead I get the following error:
2019-06-09 12:18:37 ERROR (SyncWorker_14)homeassistant.components.google_travel_time.sensor] Unable to find entity device_tracker.831cbb44_2
…which I assume is due to the fact , the device tracker entity hasn’t yet appeared. However once the device tracker entity does appear, the google_travel_time sensor (time_from_home) never appears.
Just to check that the google_travel_time sensor otherwise still works, if I use coordinates instead of device_tracker such as:
origin: 38.52000045776367,-82.7064815
scan_interval: 600
Which results in the sensor being created:
Any help will be much appreciated. I have several google_travel_time sensors and of course none of these are working. Perhaps there is some way for the device_tracker entity to retain its state and attributes after a reboot?
