I just installed 4 Gosund SW1 switches in my house and used Tuya-Convert to get them provisioned on ESPHome to integrate with Home-Assistant, I am using the following YAML configuration in ESPHome for all 4 switches:
esphome:
platform: ESP8266
board: esp01_1m
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Guest Switch Fallback Hotspot"
password: !secret backup_ap_password
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
password: !secret api_password
ota:
password: !secret ota_password
# TODO: Figure out how to get the status_led to turn off when the lights are off, right now this LED stays on continuously
status_led:
pin:
number: GPIO02
inverted: no
binary_sensor:
- platform: gpio
name: "Guest Room Switch Button"
pin:
number: GPIO00
mode: INPUT_PULLUP
inverted: True
on_press:
- switch.toggle: relay
switch:
- platform: gpio
name: "Guest Room Switch Relay"
pin: GPIO14
- platform: wifi_signal
name: "Guest Room Switch WiFi signal"
update_interval: 60s
- platform: uptime
name: "Guest Room Switch uptime"
text_sensor:
- platform: version
name: "Guest Room Switch ESPHome version"
The problem is the status_led remains “ON” continuously. Ideally I’d like the original behavior back whereby when the lights are ON the LED is ON, and when the lights are OFF the LED is OFF. I do realized the purpose of the status_led is to report if there are issues, so I suspect I want both behaviors both the status_led to report issues, but also behave like it was originally intended, if no issues the LED should be OFF when the lights are OFF, but should be ON when the lights are ON, unless there is a status that might cause it to blink otherwise. Any suggestions on how I might be able to get this to behave?
maybe you can use the information from this site: https://templates.blakadder.com/gosund_SW1.html
For your configuration i would set inverted: yes for the LED. I have no idea if your Gosund SW1 has 2 LED’s, but the Tasmota template configure a green and a red one.
I did see that guide, and I have tried using GPIO16 per that document and that simply changed the color from green to red, also when I set inverted: yes the led stays off, no changes when switching the lights on or off, this happens in both cases (GPIO02 & GPIO16).
