Thanks for all the help…never would have got it going without it!
I took the day off so I would not be interrupted and I got the Wallmote to open and close my garage door. I also got it to LOCK the backdoor but not UNLOCK it.
Look at the bottom correctly as it is saying that is not implemented. Yet it works from the HA homepage.
Mon Nov 04 2019 20:14:25 GMT-0600 (Central Standard Time)
Error while executing automation automation.wallmote_unlock_back_door. Unknown error for call_service at pos 1:
File “/usr/src/homeassistant/homeassistant/components/automation/init.py”, line 437, in action
await script_obj.async_run(variables, context)
File “/usr/src/homeassistant/homeassistant/helpers/script.py”, line 190, in async_run
await self._handle_action(action, variables, context)
File “/usr/src/homeassistant/homeassistant/helpers/script.py”, line 274, in _handle_action
await self._actions[_determine_action(action)](action, variables, context)
File “/usr/src/homeassistant/homeassistant/helpers/script.py”, line 357, in _async_call_service
context=context,
File “/usr/src/homeassistant/homeassistant/helpers/service.py”, line 97, in async_call_from_config
domain, service_name, service_data, blocking=blocking, context=context
File “/usr/src/homeassistant/homeassistant/core.py”, line 1236, in async_call
await asyncio.shield(self._execute_service(handler, service_call))
File “/usr/src/homeassistant/homeassistant/core.py”, line 1261, in _execute_service
await handler.func(service_call)
File “/usr/src/homeassistant/homeassistant/helpers/entity_component.py”, line 213, in handle_service
self._platforms.values(), func, call, service_name, required_features
File “/usr/src/homeassistant/homeassistant/helpers/service.py”, line 348, in entity_service_call
future.result() # pop exception if have
File “/usr/src/homeassistant/homeassistant/helpers/service.py”, line 370, in _handle_service_platform_call
await getattr(entity, func)(**data)
File “/usr/local/lib/python3.7/concurrent/futures/thread.py”, line 57, in run
File “/usr/src/homeassistant/homeassistant/components/lock/init.py”, line 133, in open
raise NotImplementedError()
NotImplementedError
Also if I got to the developer options and bring up the service and try to run it, I get "failed to call service lock/unlock
Has anyone seen this error before? Thank you.
