I am struggling to get a window and door sensor to work up in HA. It’s not seen via Bluetooth, but the documentation page indicates this one should be seen.
Any advise?
Any advise?
Bluetooth range is small. It’s also finicky.
I suggest ESPHome Bluetooth Proxy’s id you are integrationg Bluetooth devices.
Thank you. I will try putting the device closer and see if its discovered. I will also go research ESPHome Bluetooth proxys, i have not read up on that yet.
