I am trying to setup the Govee local integration for a strip light I just put in, but it seems that it does not exist in the integrations search. When I use the blueprint button on the integration page I get the error:
“This integration does not support configuration via the UI. If you followed this link from the Home Assistant website, make sure you run the latest version of Home Assistant.”
There is no way to configure it via the configuration yaml file. Any ideas?
I see that others have it setup
I’m running into this same issue. The “Add Integration” button on the integration page fails with the error that @Noahma describes and I can’t find “Govee Lights Local” when trying to add from the “Add Integration” button from Settings/Devices.
I do have the HACS Govee integration installed. Do I need to remove that for the local Govee integration to work?
Until a solution is found, I am using the Hacs integration. I did not preciously have that one installed, and the official integration was not showing up in the add integration page
Bumping because I am having the same issue. I have the Govee integration and the Govee2MQTT integration installed, but I cannot find the Govee Lights Local Integration. Does this require a specific version of HA or something?
The answer is yes. Removing the HACS integration by LaggAt solved the issue. I guess having the same name as the official one makes it not play nice together.
