Govee Thermometer / Hygrometer — Home Assistant Integration
Created using Claude Code
A HACS-compatible custom integration that pulls temperature, humidity, and online status from Govee WiFi thermometers and hygrometers using the Govee OpenAPI.
Supported Devices
SKU Device Temperature Humidity
H5103 GoveeLife WiFi Thermometer H5103 :white_check_mark: :white_check_mark:
H5179 WiFi Thermo-Hygrometer H5179 :white_check_mark: :white_check_mark:
H5100 Thermo-Hygrometer H5100 :white_check_mark: :white_check_mark:
H5101 Thermo-Hygrometer H5101 :white_check_mark: :white_check_mark:
H5102 Thermo-Hygrometer H5102 :white_check_mark: :white_check_mark:
H5104 Thermo-Hygrometer H5104 :white_check_mark: :white_check_mark:
H5055 GoveeLife WiFi Pool Thermometer P1 :white_check_mark:
H5056 Pool Thermometer H5056 :white_check_mark:
Don't see your device? Open an issue — adding a SKU is a one-line change.
Prerequisites
  1. Govee Developer API key — request one from the Govee Home app:
    Settings → About Us → Apply for API Key
    (or visit developer.govee.com)
  2. Home Assistant 2024.1 or newer
  3. HACS installed
Installation
Via HACS (recommended)
  1. In HACS → Integrations → ⋮ → Custom repositories
  2. Add https://github.com/Conexo-Casa/govee-thermometer-ha — category Integration
  3. Install Govee Thermometer / Hygrometer and restart Home Assistant
Manual
Copy custom_components/govee_thermometer/ into your HA config/custom_components/ directory and restart.
Configuration
  1. Settings → Devices & Services → Add Integration
  2. Search for Govee Thermometer
  3. Enter your API key
All matching sensor devices on your account are discovered automatically.
No, I cannot provide support or modifications.
Yes, you can fork this repo and make your own changes.
Can you add the H5112?
Can you add H5111?
