Hi, I had installed govee2mqtt about a year ago and it was working flawlessly for my govee downlights which require LAN port 4002. The issue seems to be that matter is now binding port 4002 and the govee2mqtt add on cannot bind to that port and all of my downlights are unavailable in HA.
I’ve tried uninstalling a number of times, killing/uninstalling matter server (HA doesn’t really let you). I’ve tried to SSH in and modify the UDP port for the govee2mqtt add on but had no luck and probably would just break the connection for the lights to HA anyway. I also tried to downgrade the matter server version just to see if older versions fix it.
I have HA Green
Lights are Govee H601A and H601B
This is the specifc error I’m seeing:
Error: Cannot bind to UDP Port 4002, which is required for the Govee LAN API to function. Most likely cause is that you are running another integration (perhaps \ Govee LAN Control, or homebridge-govee) that is already bound to that port. Both cannot run on the same machine at the same time. Consider disabling Govee LAN Controlor settinglanDisableinhomebridge-govee.
I do not have Govee LAN Control or homebridge-govee installed now or ever
Any help would be greatly appreciated!
