Govee2MQTT Help Defaults to one color
I’ve made the switch to Govee 2 MQTT and I am having some major errors. From what I can gather is that once I set up my string lights to hook up to the network, it defaults the color to solid purple. I can go into the app and attempt to change the color. The lights respond by blinking once in that color and defaulting to purple again.
I have been at this for days now and the only thing I have noticed is this:
  1. Reset lights to factory settings
  2. change the color of the lights using the Govee App, but only on bluetooth mode
  3. once I hook up the lights to the network, BOOOM they are purple.
I have used to have them linked to Amazone Alexa with helpers to switch the colors. I have deleted all that and also unlinked the Amazon completely. Still having the same issues.
Can someone help???
Here is the MQTT log:
  "http": null,
  "iot": {
    "brightness": 100,
    "color": {
      "b": 92,
      "g": 0,
      "r": 63
    "kelvin": 0,
    "light_on": true,
    "on": true,
    "online": null,
    "scene": null,
    "source": "AWS IoT API",
    "updated": "2025-10-23T22:34:49.337002360Z"
  "lan": {
    "brightness": 100,
    "color": {
      "b": 92,
      "g": 0,
      "r": 63
    "kelvin": 0,
    "light_on": true,
    "on": true,
    "online": null,
    "scene": null,
    "source": "LAN API",
    "updated": "2025-10-23T22:34:05.359238376Z"
  "overall": {
    "brightness": 100,
    "color": {
      "b": 92,
      "g": 0,
      "r": 63
    "kelvin": 0,
    "light_on": true,
    "on": true,
    "online": null,
    "scene": null,
  "platform_metadata": {
    "capabilities": [
        "alarmType": null,
        "eventState": null,
        "instance": "powerSwitch",
        "parameters": {
          "dataType": "ENUM",
          "options": [
              "name": "on",
              "value": 1
              "name": "off",
              "value": 0
        "type": "devices.capabilities.on_off"
        "alarmType": null,
        "eventState": null,
        "instance": "gradientToggle",
        "parameters": {
          "dataType": "ENUM",
          "options": [
              "name": "on",
              "value": 1
              "name": "off",
              "value": 0
        "type": "devices.capabilities.toggle"
        "alarmType": null,
        "eventState": null,
        "instance": "brightness",
        "parameters": {
          "dataType": "INTEGER",
          "range": {
            "max": 100,
            "min": 1,
            "precision": 1
          "unit": "unit.percent"
        "type": "devices.capabilities.range"
        "alarmType": null,
        "eventState": null,
        "instance": "segmentedBrightness",
        "parameters": {
          "dataType": "STRUCT",
          "fields": [
              "dataType": "Array",
              "defaultValue": null,
              "elementRange": {
                "max": 14,
                "min": 0
              "elementType": "INTEGER",
              "fieldName": "segment",
              "options": [],
              "required": true,
              "size": {
                "max": 15,
                "min": 1
              "fieldName": "brightness",
              "range": {
                "max": 100,
                "min": 0,
                "precision": 1
              "required": true,
              "unit": null
        "type": "devices.capabilities.segment_color_setting"
        "alarmType": null,
        "eventState": null,
        "instance": "segmentedColorRgb",
        "parameters": {
          "fields": [
              "elementRange": {
                "max": 14,
                "min": 0
              "options": [],
              "required": true,
              "size": {
                "max": 15,
                "min": 1
              "fieldName": "rgb",
              "range": {
                "max": 16777215,
                "min": 0,
                "precision": 1
              "required": true,
              "unit": null
        "alarmType": null,
        "eventState": null,
        "instance": "colorRgb",
        "parameters": {
          "range": {
            "max": 16777215,
            "min": 0,
            "precision": 1
          "unit": null
        "type": "devices.capabilities.color_setting"
        "alarmType": null,
        "eventState": null,
        "instance": "colorTemperatureK",
        "parameters": {
          "range": {
            "max": 9000,
            "min": 2000,
            "precision": 1
          "unit": null
        "alarmType": null,
        "eventState": null,
        "instance": "lightScene",
        "parameters": {
          "dataType": "ENUM",
          "options": []
        "type": "devices.capabilities.dynamic_scene"
        "alarmType": null,
        "eventState": null,
        "instance": "musicMode",
        "parameters": {
          "fields": [
              "dataType": "ENUM",
              "fieldName": "musicMode",
              "options": [
                  "name": "Energic",
                  "value": 1
                  "name": "Rhythm",
                  "value": 2
                  "name": "Spectrum",
                  "value": 3
                  "name": "Rolling",
                  "value": 4
                  "name": "Separation",
                  "value": 5
                  "name": "Hopping",
                  "value": 6
              "required": true
              "fieldName": "sensitivity",
              "range": {
                "max": 100,
                "min": 0,
                "precision": 1
              "required": true,
              "dataType": "ENUM",
              "fieldName": "autoColor",
              "options": [
                  "name": "on",
                  "value": 1
                  "name": "off",
                  "value": 0
              "required": false
              "fieldName": "rgb",
              "range": {
                "max": 16777215,
                "min": 0,
                "precision": 1
              "required": false,
              "unit": null
        "type": "devices.capabilities.music_setting"
        "alarmType": null,
        "eventState": null,
        "instance": "diyScene",
        "parameters": {
          "dataType": "ENUM",
          "options": []
    "device": "45:E9:CA:32:38:31:36:1A",
    "deviceName": "LED Bulb String Lights",
    "sku": "H7041",
    "type": "devices.types.light"
  "platform_state": null
Can anyone assist at all? I have deleted all the apps on my accessories, started over from scratch and somehow there is something still turning my lights on. It’s almost like an automation that exists, but there is no connection to the lights. It also forces it to a default color I cannot change. During the day outside the timer of the lights, i can control the lights.
I have run several diagnostics. All I can do with the string is change the brightness. I am unable to change the color in the APP or Govee2MQTT in Home Assistant. Can anyone help out?
