Govee2MQTT not recognizing H1616D strip lights correctly
Has anyone else ran in this issue?
The H616D is successfully discovered, and state data is being received via AWS IoT API, but Govee2MQTT reports “Unknown device type. Cannot map to Home Assistant.” As a result, no control entities (light, brightness, color) are created in Home Assistant. As a result there is no on/off or color selection options available.
Seems there is an open incident about it from a while ago with no response.
Add support for H616D (2*7.5m RGBIC Outdoor Strip Lights 2) · Issue #577 · wez/govee2mqtt
Or do I have to just dump this and go to a different Govee integration?
UPDATE: I changed this one device settings in the Govee app to “LAN Control” = enabled. It seems to work after this even though I have my Govee devices on a separate IOT network. Nothing I could see in docs that this was required to function.
