GPIO on raspberry
HI,
I have a problem with a relay module connected to raspberry GPIO.
When I start Hass service the relay stay switched, I try to change invert logic true/false but it’s always on.
here’s my code:
switch:
  - platform: rpi_gpio
    ports:
      17: rel3
      18: rel4
    invert_logic: true
can anybody help?
thanks.
I have the same problem and the same configuration, have you found a solution? Thank you!!!
Use the 3.3V output on the raspberry instead of 5V.
Thank you so much, it works, it was so easy :slight_smile:
