Hi, I am new to Home Assistant and I’m looking to convert my home from OH to HA. Extensive searching has not helped. I am still getting my head around the HA setup and configuration ecosystem. I am trying to migrate a handful of MQTT sensors and an Arlec Remote controlled outlets.
Currently these are connected to the GPIO’s on my RPi and work through an interface board that I found here https://core-electronics.com.au/projects/p0wer-control-mains-outlets-over-wifi
This works really well with OH, albeit with MQTT and Node-red thrown into the mix.
My question is, has anybody done this with Home Assistant? If so, can you please post your config? I am pretty sure I have the GPIO Binary_sensor and switch sorted.
Really looking for a nudge in the right direction.
I am slowly configuring a second Rpi so as to not impact my current home automation setup.
