@estley
I get asked this same question / scenario a lot for the SpotifyPlus Integration. Here’s the How do I access dictionary items from a Service Response topic I put together for my FAQ wiki page that explains the issue in more detail.
Hope it helps!
All of the SpotifyPlus services that retrieve data from the Spotify Web API will return the data in a dictionary format in the service response. The data can then be processed in a template and used however you wish.
For example, consider the following service call to retrieve all albums for an artist:
action: spotifyplus.get_artist_albums
entity_id: media_player.spotifyplus_todd_l
artist_id: 6APm8EjxOHSYM5B4i3vT3q
include_groups: album
limit_total: 10
sort_result: true
The results would look like this (shortened for brevity, actual result will contain MUCH more data):
result:
date_last_refreshed: 1739564010.147239
items:
- album_type: album
artists:
- id: 6APm8EjxOHSYM5B4i3vT3q
uri: spotify:artist:6APm8EjxOHSYM5B4i3vT3q
image_url: https://i.scdn.co/image/ab67616d0000b2732e7368a96604933f6a87b97a
total_tracks: 25
uri: spotify:album:2ezUrMWSvn9nYsI6DvdCgW
- album_type: album
artists:
image_url: https://i.scdn.co/image/ab67616d0000b2733e8dc4e2eb7551afa8db3339
name: All That Is Within Me
total_tracks: 10
uri: spotify:album:4nZS59zzTABfnSPq7a9iP1
The Problem
When you go to process the data in your template processing, your first thought is to access the repeating items
collection data using something like this:
artist_name: "{{serviceResponse.result.items[0].name}}"
which will result in an error that looks like this:
Error rendering data template: UndefinedError: builtin_function_or_method object has no element 0.
Keep in mind that you are processing data that is returned in a dictionary using Python; the Python dictionary class has a METHOD named items
, which is not to be confused with the items
KEY that is returned in the dictionary. The result.items[0].name
statement is trying to call the Python items
METHOD, which results in the builtin_function_or_method object has no element 0
error.
The Solution
You have to reference items
as a dictionary KEY so that it’s not inferred as a METHOD, like so:
artist_name: "{{serviceResponse.result['items'][0].name}}"
Here’s a simple example I tested in the HA Developer Tools \ Templates
editor:
set serviceResponse = {
"result": {
"items": [
"artists": [
"name": "MercyMe",
"uri": "spotify:artist:6APm8EjxOHSYM5B4i3vT3q"
"image_url": "https://i.scdn.co/image/ab67616d0000b2732e7368a96604933f6a87b97a",
"name": "10",
"uri": "spotify:album:2ezUrMWSvn9nYsI6DvdCgW"
"artists": [
"name": "MercyMe",
"image_url": "https://i.scdn.co/image/ab67616d0000b2733e8dc4e2eb7551afa8db3339",
"name": "All That Is Within Me",
"uri": "spotify:album:4nZS59zzTABfnSPq7a9iP1"
Artist Albums: {{"\n"}}
{%- for item in serviceResponse['result']['items'] -%}
{%- set trackName = item['name'] | default('') -%}
{%- set trackImageUrl = item['image_url'] | default('') -%}
{%- set trackUri = item['uri'] | default('') -%}
{%- set trackArtist = item['artists'][0]['name'] | default('') -%}
- {{ trackName }} ({{trackUri}}) - {{ trackArtist }} {{"\n"}}
{%- endfor -%}
{{"\n"}}
1st item result A = {{ serviceResponse['result']['items'][0]['uri'] }}
1st item result B = {{ serviceResponse.result['items'][0].uri }}
1st item result C = {{ serviceResponse.result.items[0].uri }} <- this fails
