Grafana addon on Virtual Machine - how to access?
Grafana addon working perfectly under the latest HASS Supervised on a VM on Synology NAS.
I have been unable to set up direct access to Grafana - so that I don’t have to go via HA to access Grafana.
Under Grafana Configuration I added port 3000. When I try access that port with the VM’s local IP address, nothing loads.
My goal is to provide syslog data from Synology’s Log Center to a ‘Synology Dashboard’ in Grafana. I add the IP of of HA and the port but the data is not getting received on the Grafana side.
Any help would be appreciated.
