Hi all,
I’m running Hassio on a NUC, and have Influx installed as an add-on.
Tried to install Grafana also as an add-on. I assume the iframe option is the best to have best live data on my graphs (or am I mistaken?).
My issue is that the OAuth keep failing after session is timing out, and according to other posts, this can not be resolved through the add-on. My question is then;
- Will it work with iframe if I install Grafana as a standalone docker on my NUC?
- What recommended docker compose should I use?
