Gree Airo/heater temp sensor
Hello. I’m new here and have been happily tinkering with home automation with HA for a while now. I’ve run into a problem and would like some support. I hope I’m asking this in the right place. If not, my apologies. We have four GREE air conditioners/heaters. They work perfectly with HA, but it doesn’t always select the correct temperature sensor when starting up. There’s an outside temperature sensor and an inside temperature sensor. Does anyone know a way to select the inside temperature sensor?
How many GREE related temperature sensor entities are showing in HomeAssistant? One or four?
How does your solution select what to do for startup?
Only 1 climate sensor.
hvac_modes: auto, cool, dry, fan_only, heat, off
min_temp: 8
max_temp: 30
target_temp_step: 1
fan_modes: auto, low, medium low, medium, medium high, high
preset_modes: eco, away, boost, none, sleep
swing_modes: off, vertical, horizontal, both
current_temperature: 20
temperature: 19
fan_mode: low
preset_mode: none
swing_mode: both
friendly_name: Airco keuken
supported_features: 441
Which one is being reported in your integration? I only see one.
Its the inside sensor
