Hi.
Please split sensors in the integration, to be able to reference them into HA dashboards. It is annoying to see only a single sensor which when you click it will open an interface with multiple things.
And more than that, Power on and Power off is strange to be in the Mode dropdown list. It should be a distinct button, like in any other app.
edit:
btw. witch sensor attributes are you referencing to? I couldn’t find any additional attributes for the climate entities in the code of the gree integration
You are talking to me? I don’t understand your message!
For example, I don’t see a Buzzer On_Off attribute. If you call one of the functionality of the integration, in the night, I might get up with the climate in my head, because will get up all the house!
I’ve saw there is already a post on the internet on some integrations for this climate that send also this attribute in the command to the climate, Buzzer_ON_OFF=1.
AC Sala - is the sensor named climate.< macaddress > … everything in that card is one sensor, which probably contains other sensors, I don’t know …
Is any possible way to get for example only the power on/ power off sensor outside that climate sensor?
