Hi.
According to the Gree manual, I see this is possible:
Is there any way of doing this, as long I have an automation which start my Gree climate if my inverter’s active power is above 1.5kW ?
So, as an example, if the climate is starting in Heat mode, then the UD fixed angle must be set in the lower position, if the climate is starting in Cool mode, then the UD fixed angle must be set in the upper position.
Thanks.
