TH-Braemer
(Th Braemer)
November 26, 2025, 1:34pm
1
Hi
I have three electricity meters in our house, and I’m reading six values from each.
They are on the same modbus line, but clearly they are on three different modbus-controllers.
My issue is, right now, they are read one node at a time, and the values does not appear in HomeAssistant at the same time.
I’m doing som calculations in HA, but since the values are not read at the (nearly) same time, I get a lot of spikes.
Does anyone know of a way or a trick to not send the values to HA until all three nodes have been read?
Karosm
(Karosm)
November 26, 2025, 1:45pm
2
Wouldn’t it be better to do calculations on esphome?
TH-Braemer
(Th Braemer)
November 26, 2025, 1:55pm
3
Then I need to change a lot, and will loose historical data.
Some of the calculations are done on statistical entities based on modbus readings.
I changed from a RS485 USB-Stick to ESPHome to get it done wirelessly, and I therefore have, I guess, two years of historical data that I will lose, if I change the entities in HA
Karosm
(Karosm)
November 26, 2025, 2:21pm
4
Post your code (with code tags).
TH-Braemer
(Th Braemer)
November 30, 2025, 10:52am
5
Sorry for the delay
Here’s the code for reading the nodes
uart:
- id: uart_iem3155
rx_pin: GPIO12 # D6
tx_pin: GPIO14 # D5
baud_rate: 38400
data_bits: 8
parity: EVEN
stop_bits: 1
modbus:
- id: modbus_iem3155
uart_id: uart_iem3155
modbus_controller:
- id: modbus_house_meter
address: 1
modbus_id: modbus_iem3155
setup_priority: -10
update_interval: 10s
- id: modbus_solar_meter
address: 2
setup_priority: -10
- id: modbus_charge_box_meter
address: 3
setup_priority: -10
# https://esphome.io/components/number/modbus_controller/
## Houese-Meter - ReadModbusActual ##
# Read Actual import
# readHoldingRegisters( 3053, 8 ) - P1, P2, P3, Ptot (hver er Float32)
# 0-1 => P L1
# 2-3 => P L2
# 4-5 => P L3
# 6-7 => P Ltot
- platform: modbus_controller
modbus_controller_id: modbus_house_meter
name: "T - iem3155modbus - House-Meter - Actual - L1"
register_type: holding
address: 3053
unit_of_measurement: "W"
value_type: FP32
accuracy_decimals: 0
filters:
- multiply: 1000.0
name: "T - iem3155modbus - House-Meter - Actual - L2"
address: 3055
value_type: FP32
filters:
- multiply: 1000.0
name: "T - iem3155modbus - House-Meter - Actual - L3"
address: 3057
value_type: FP32
filters:
- multiply: 1000.0
name: "T - iem3155modbus - House-Meter - Actual - All"
address: 3059
value_type: FP32
filters:
- multiply: 1000.0
## Houese-Meter - ReadModbusTotal ##
# Read Total Import
# readHoldingRegisters( 3203, 4 ) - hver er Int64
# Total Import: Importeret til husstanden (+ forbrugt af inverteren)
name: "T - iem3155modbus - House-Meter - Import"
address: 3203
unit_of_measurement: "kWh"
value_type: S_QWORD
accuracy_decimals: 3
filters:
- multiply: 0.001
# Read Total Export
# readHoldingRegisters( 3207, 4 ) - hver er Int64
# Total Export: Eksporteret fra husstanden
name: "T - iem3155modbus - House-Meter - Export"
address: 3207
value_type: S_QWORD
filters:
- multiply: 0.001
## Solar-Meter - ReadModbusActual ##
# 0-1 => P L1
# 2-3 => P L2
# 4-5 => P L3
# 6-7 => P Ltot
modbus_controller_id: modbus_solar_meter
name: "T - iem3155modbus - Solar-Meter - Actual - L1"
address: 3053
value_type: FP32
filters:
- multiply: 1000.0
name: "T - iem3155modbus - Solar-Meter - Actual - L2"
address: 3055
value_type: FP32
filters:
- multiply: 1000.0
name: "T - iem3155modbus - Solar-Meter - Actual - L3"
address: 3057
value_type: FP32
filters:
- multiply: 1000.0
name: "T - iem3155modbus - Solar-Meter - Actual - All"
address: 3059
value_type: FP32
filters:
- multiply: 1000.0
## Solar-Meter - ReadModbusTotal ##
# Read Total Import
# Total Import: På grund af den måde, som måleren er monteret på, så er Import => produceret (fra inverteren) - Af hensyn til logikken er dette omvendt i HA => Export er produceret for inverteren
name: "T - iem3155modbus - Solar-Meter - Import"
address: 3203
value_type: S_QWORD
filters:
- multiply: 0.001
# Read Total Export
# Total Export: På grund af den måde, som måleren er monteret på, så er Export => forbrugt (til inverteren) - Af hensyn til logikken er dette omvendt i HA => Import er forbrugt for inverteren
name: "T - iem3155modbus - Solar-Meter - Export"
address: 3207
value_type: S_QWORD
filters:
- multiply: 0.001
## Charge-Box-Meter - ReadModbusActual ##
# 0-1 => P L1
# 2-3 => P L2
# 4-5 => P L3
# 6-7 => P Ltot
modbus_controller_id: modbus_charge_box_meter
name: "T - iem3155modbus - Charge-Box - Actual - L1"
address: 3053
value_type: FP32
filters:
- multiply: 1000.0
name: "T - iem3155modbus - Charge-Box - Actual - L2"
address: 3055
value_type: FP32
filters:
- multiply: 1000.0
name: "T - iem3155modbus - Charge-Box - Actual - L3"
address: 3057
value_type: FP32
filters:
- multiply: 1000.0
name: "T - iem3155modbus - Charge-Box - Actual - All"
address: 3059
value_type: FP32
filters:
- multiply: 1000.0
## Charge-Box-Meter - ReadModbusTotal ##
# Read Total Import
name: "T - iem3155modbus - Charge-Box - Import"
address: 3203
value_type: S_QWORD
filters:
- multiply: 0.001
# Read Total Export
name: "T - iem3155modbus - Charge-Box - Export"
address: 3207
value_type: S_QWORD
filters:
- multiply: 0.001
