Grouping binary toggles together in groups
Hi all,
I recently created a bunch of toggle helpers that i want to use to disable home automation per room.
So each room has a toggle. But i also want those individual rooms grouped into an “upstairs”, “downstairs” , “outside” and “inside” toggle. I think you get the idea.
And those toggles i want to group under 1 master toggle.
I have been messing around with the groups but i can’t seem to make it work
Can anyone nudge me in the right direction. preferably with a small config example.
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
  - platform: google_translate
  - platform: marytts
    port: 5500
    voice: larynx:harvard-glow_tts
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
light: !include light-groups.yaml
sensor: !include sensors.yaml
binary_sensor: !include binary-sensors.yaml
switch: !include switches.yaml
homeassistant:
  customize: !include customize.yaml
frontend:
    themes: !include_dir_merge_named themes
octoprint:
  host: octoprint.local
  api_key: !secret octoprint_api_key
  bed: true
  number_of_tools: 1
device_tracker:
  - platform: bluetooth_tracker
my groups.yaml is empty at the moment
In groups.yaml:
all_upstairs:
  entities:
  - input_boolean.upstairs_1
  - input_boolean.upstairs_2
  - input_boolean.upstairs_3
all_downstairs:
  name: All Downstairs
  entities:
  - input_boolean.downstairs_1
  - input_boolean.downstairs_2
  - input_boolean.downstairs_3
everything:
  entities:
  - group.all_upstairs
  - group.all_downstairs
Thanks! i added the - sign before name parameter. i guess that was my error.
