I’m trying to create a group with a light (mqtt), and it doesn’t seem to be recognizing that the light is listed in the group. I’ve tried view: yes and view: no to no avail… the light continues to appear only in the “home” default view.
Unfortunately all I have to go by is the documentation. What does HA think the light is called? in the left hand menu click on the <> symbol at the bottom, scroll down and find the light and see what name HA has given it internally. That’s the name you need to use in the group as the entity.
Bingo. It seems that this whole time I’ve thought it was basing the entity name on the “sensor :” or “light :” identifier… turns out up until now I’ve ‘accidentally’ been setting the "name: " to be the same as the id, and thus it has worked.
Thank you so much… I should know better than to assume
