from reload, office and person are showing up correctly in the dashboard, however camera and mediadevice groups are not showing up in group, anything I missed?
thanks for the hint. changed the group name to something else, reload, restart, still the same. the last 2 groups didn’t show up in the UI. and there is no error in the HA output (attached the container in a terminal).
I don’t know why they wouldn’t automatically show up because I don’t use the default Lovelace view but it would be better for you if you took control of your UI and configured it yourself.
If you’ve installed in the last 10 months or so you are already on lovelace. You just haven’t taken control of the config by either using yaml mode or configuring it thru the GUI.
If you don’t one of those things then the system generates a basic frontend UI for you.
