Hi All, first post so please be kind
I have been using HomeAssistant for a while and have managed to find everything I need online, but this one has me stumped even after lots of searching.
I have a Growatt Inverter (SPH3~6k TL BL) with a datalogger (ShineWIFI-S) setup with Grott add-on (Beta branch 2.8 v0.1.7). HA is 2024.3.3 running on HA OS 12.1.
This has been working successfully for months without any issues until I went away last week and came home to it not working. The immediate suspect was the wi-fi datalogger, mine has a habit of losing the Wi-Fi every now and again, so reconnected that and itâs working OK sending data to Growatts Servers but not Grott.
Investigation showed that the datalogger server IP wasnât set, so went into Growatt web site and re-set the server IP of the datalogger to my internal 192.168.1.19 address for the Grott server. Bingo, all worked, no problem.
10 minutes later it stopped. This now happens completely consistently, set the IP and the datalogger uses it for 10 mins (exactly, I have it set to 1min updates and it always sends 10 to Grott, can see them in the logs) then it ignores the IP and reverts to sending data direct to the Growatt cloud servers.
I have tried resetting the datalogger dongle completely, gone into local mode on it and set the IP directly using the local app. Everything works for 10 mins and then reverts.
I can see that in grott IP mode the data is getting looped through Grott to Growatt-Cloud and growatt is getting the updates, can see these in the growatt website.
Have tried all the basics, reboot HA, install latest Grott, uninstall Grott, re-install Grott.
Any thoughts? Anyone experienced anything similar?
