Growatt ShinePhone account locked after enabling Growatt integration (ShineWiLan‑X2, HAOS, need safe polling strategy)
Growatt ShinePhone account locked after enabling Growatt integration (need safe best‑practice with API token & scan_interval)
Context / Goal
I’m trying to integrate my Growatt hybrid inverter + APX battery into Home Assistant OS (HAOS) in a way that:
  • Keeps my existing Growatt cloud monitoring fully working
  • Keeps the ShinePhone app fully usable at all times
  • Avoids any risk of Growatt locking my account again because of API usage from HA
After enabling the Growatt integration in HA, my ShinePhone app account was locked, while I could still log in to the Growatt web portal. I want to understand what the safest best‑practice is (API token + scan interval, separate account, etc.) so this never happens again.
System description
  • Location / setup
    • Residential + small business setup in the Netherlands
    • 8 kWp PV (20x Jinko Tiger Neo 400 Wp, east–west)
    • Hybrid inverter: Growatt MOD 7000TL3-XH BP
    • Battery: Growatt APX HV 10 kWh
    • 3‑phase backup box: SYN100XH30
    • EV charger: Growatt THOR 11 kW
    • Growatt datalogger: ShineWiLan‑X2, S/N ZGQ0F6M145 (WiFi + LAN)
  • Home Assistant
    • Hardware: Gigabyte BRIX mini‑PC (Intel N200, 16 GB RAM, SSD)
    • Install: Home Assistant OS (official HAOS image)
    • Role: central EMS (energy management system) for:
      • Dynamic electricity pricing (EnergyZero / Greenchoice, NL)
      • Battery control (charge / discharge strategy)
      • EV charging strategy
      • General home automation
What I did (and what went wrong)
  1. I added the Growatt integration in Home Assistant (Growatt Server) to get:
  • PV production
  • Battery SoC / charge / discharge power
  • Grid import / export
  1. After enabling this integration, my ShinePhone app suddenly reported my account as “locked” / blocked.
  • I could still log in to the Growatt web portal (server.growatt.com) with the same credentials.
  • The lock seemed to apply to the app / API side, not the portal.
  1. I then removed the Growatt integration from HAOS to stop further API calls from Home Assistant.
  • My goal was to prevent making the situation worse and to avoid permanent issues with my account.
From what I’ve found online and from my own analysis, this looks like a Growatt rate‑limit / security lock because HA was polling the API too aggressively (or with the same account that the ShinePhone app uses).
Current status
  • ShinePhone app: currently locked / unreliable (message about the account being locked).
  • Growatt web portal: still accessible with my login.
  • HAOS: Growatt integration is currently removed; no more Growatt API calls are being made from Home Assistant.
  • I strongly want to keep full control via the ShinePhone app – this is non‑negotiable for me. I do not want to flash hardware or sacrifice the official Growatt cloud monitoring.
What I want to achieve
My desired end‑state:
  • Growatt cloud + ShinePhone keep working exactly as designed.
  • Home Assistant gets Growatt data (PV, battery, grid) safely and reliably.
  • No account locks / rate‑limit issues at Growatt due to HA.
I’m not looking for complex MQTT / Grott / custom firmware solutions right now. I know they exist and might be more robust long‑term, but at this moment I want:
A safe configuration using the official Growatt integration with an API token, possibly with a separate HA‑only account and a conservative scan_interval (5–10 minutes), that the community considers “best practice” and that doesn’t risk another lock.
Planned approach (please sanity‑check / correct me)
This is the plan I intend to follow once my ShinePhone app access is restored:
  1. Reset security at Growatt side
  • Change the password of my main Growatt account via the web portal (server.growatt.com).
  • If possible, create a second user / visitor account specifically for Home Assistant (read‑only if available).
  1. Use an API token for HA
  • Log in with the HA‑specific account in the ShinePhone app.
  • Generate an API token / third‑party access token (as described in various guides and in my own system documentation).
  • Store this token securely.
  1. Re‑add the Growatt integration in HA
  • In Home Assistant:
    Settings → Devices & Services → Add Integration → Growatt Server
  • Use the API token instead of username/password.
  • Set the server / region to Other region / server.growatt.com (I’m in Europe, NL).
  1. Set a safe polling interval
  • Use the default ~5‑minute update or explicitly configure scan_interval to 300–600 seconds (5–10 minutes).
  • Make sure no other tools are logging into the Growatt API with the same account (no extra scripts, no additional Growatt integrations, etc.).
  1. Monitor behaviour
  • For the first days, monitor:
    • ShinePhone app login behaviour.
    • HA entity updates (that they keep changing every few minutes).
  • Optionally create a simple HA automation that warns me if a key Growatt sensor (e.g. battery SoC) doesn’t change for more than ~30 minutes, so I can catch issues early before Growatt decides to block the account again.
Questions for the community
  1. Is this approach (API token + separate HA account + 5–10 min scan interval) considered “safe” and “normal” by people running Growatt + HAOS long‑term without ShinePhone lock issues?
  2. Does anyone have concrete experience with Growatt account locks specifically caused by the HA Growatt Server integration, and what exact settings / patterns caused or avoided those locks?
  3. For users with ShineWiLan‑X2:
  • Are there any known caveats when using the official Growatt integration (API token) together with ShineWiLan‑X2 on server.growatt.com?
  • Any reason to prefer a 10‑minute scan_interval over 5 minutes to be on the safe side?
  1. Are there any recommended config examples for:
  • Using the Growatt Server integration only for reading (PV, battery, grid)
  • With a conservative scan interval
  • Without touching modes / settings on the Growatt side
  1. Finally: Is there anything obvious I am missing that could prevent a future lock, given that:
  • I have a fairly “heavy” energy setup (PV, APX battery, EV charger, dynamic prices).
  • I want HA to be the main EMS, but I also want the official Growatt monitoring + ShinePhone to remain fully functional and reliable.
Home Assistant details
  • Installation: Home Assistant OS on Gigabyte BRIX (Intel N200, 16 GB RAM, SSD)
  • HA role: primary EMS, with:
    • EnergyZero / dynamic electricity pricing (NL)
    • P1 smart meter integration
    • Future automations for Growatt APX battery and EV charging (Mazda MX‑30 R-EV + Growatt THOR 11 kW)
If needed, I can also share specific versions, logs, or an anonymised config snippet once I re‑enable the integration.
Thanks in advance to anyone who can share long‑term experience or best‑practice guidance – I really want to avoid another ShinePhone lock while still using Home Assistant as my main EMS.
Related threads / docs I’ve already read:
I solved it myzelf, made an second usr on Growatt, loged in with the second usr, then mad a script to delay the login for 10 min:
Blokcitaat- id: ‘1777535651568’
alias: Growatt - Voorkomen van blokkade bij herstart
description: Schakelt Growatt integratie uit bij afsluiten, en na 10 minuten weer
aan bij opstarten
triggers:
  • trigger: homeassistant
    event: start
    event: shutdown
    variables:
    growatt_config_entry_id: xx
    conditions:
    actions:
  • choose:
    • alias: Inschakelen na 10 minuten
      conditions:
      • condition: trigger
        sequence:
      • delay:
        minutes: 10
      • data:
        config_entry_id: ‘{{ growatt_config_entry_id }}’
        action: homeassistant.enable_config_entry
    • alias: Uitschakelen bij afsluiten
      conditions:
        sequence:
      • data:
        action: homeassistant.disable_config_entry
        mode: single
You have to change this: growatt_config_entry_id: xxxx
