Want som help with this…
Managed to read some on the subject. It´s not easy trying to understand how to make a lovelace card with following:
- Scheduled departure for specified bus
- Realtime departure for specified bus
Anyone?
Anyone?
I use this, it combines the regular gtfs and the realtime in one card for the bus out and into our town
type: entities
entities:
- entity: sensor.653_mouans_rt
type: custom:multiple-entity-row
state_header: RealTime
name: Mouans > Sophia 653
format: time
secondary_info: last-changed
entities:
- entity: sensor.653_aller_mouans_first
- entity: sensor.ligne_653a_mouans_corrected
format: time
- entity: sensor.653_valbonne_rt
name: Sophia > Mouans 653
format: time
entities:
- entity: sensor.ligne_653r_sophia_corrected
format: time
Looks good! And how to create the sensor/entity?
That is not what you asked…
Assuming you already setup the integration, then you have to analyse the content of the zip file (stops) (or the sqlite db that was created in /config/gtfs…and add such a thing as this to your config
origin and destination formats differe highly between gtfs providers so yous may look completely different
- platform: gtfs
origin: 00812-0608400
destination: 01998-0615200
data: gtfs_file_for_your_transport.zip
name: "Ligne2 653A Mouans"
include_tomorrow: true
This is all documented here (limited…but it is sufficient)
General Transit Feed Specification (GTFS) - Home Assistant (home-assistant.io)
And… I just read…realtime…that is a whole different ballgame then the ‘theoretical’/ list times
What is the link to your realtime dataprovider, data/api…not map,
