How do you set it?
number:
optimistic: true
unit_of_measurement: "m"
initial_value: 10
restore_value: true
min_value: -1
max_value: 720
step: 1
mode: box
It was a bug in the code. Itâs fixed now. I also added touchscreen_idle_timeout_always_on: If you set this to true the screen will timeout and blank at any time of day not just night.
substitutions:
touchscreen_idle_timeout_always_on: "true"
weather using mapping
# MAPPING
mapping:
- id: weather_icon
to: image
entries:
clear-night: clear_night_icons
cloudy: cloudy_icons
exceptional: exceptional_icons
fog: fog_icons
hail: hail_icons
lightning: lightning_icons
lightning-rainy: lightning_rainy_icons
partlycloudy: partlycloudy_icons
pouring: pouring_icons
rainy: rainy_icons
snowy: snowy_icons
snowy-rainy: snowy_rainy_icons
sunny: sunny_icons
windy: windy_icons
windy-variant: windy_variant_icons
unknown: blank_icons
unavailable: blank_icons
# TEXT SENSOR
text_sensor:
- platform: homeassistant
entity_id: $sensor_weather
on_value:
then:
- lvgl.image.update:
src: !lambda return id(weather_icon)[x];
Interesting approach. Please share a weather screen picture, if you donât mind. TY
# IMAGE
# image: !include images_mdi.yaml
# image: !include images_an.yaml
image: !include images_andr.yaml
#image: !include images_konfa.yaml
#image: !include images_merlin.yaml
https://github.com/ananyevgv/Esphome-ESP32-S3-4848S040-LVGL/blob/7df487712228d6d01b9100632ccda7b623af9e71/packages/weather_icons.yaml
There are several of them
You can use any of them, this is what I found on the Internet.
mapping is a very cool feature. I do the same thing with my button library.
All you need to do is this
packages:
# Weather packages
# Display weather forecast using direct HA action (no template sensor needed!)
# Icons are included automatically in the action file
weather_forcast_100: !include
file: esphome-modular-lvgl-buttons/weather_homeassistant/weather_forecast_action.yaml
vars:
weather_entity: weather.home
# Get todays weather and display it (icons included automatically)
weather_today_200: !include
file: esphome-modular-lvgl-buttons/weather_homeassistant/weather_today.yaml
vars:
weather_summary: sensor.home_hourly_summary
The first package builds an icon set of 100x100px images for the weather forecast from SVG file. Then it pulls the weather forecast from home assistant and displays. The second package will pull todays weather and build a 200px icon set for it. You can easily change the icon sizes when you call the library to fit your screen. Looks like this (this works for a 480x480px screen)
I have a readme here on how to use it
Thank you, Andrew. I will definitely try that later, when have a little bit more free time.
Hey!
Can the version without the relays be wall mounted in Europe (230v mains)?
Can someone point me out how can this be done? Pictures would be great, specially on the wiring.
Thanks!
Relay section also contains power supply, so if you plan to use model without that youâll have to us eyour own 5V power and bring it to the module. Then, without bakc side installing can be a problem, since front part doesnât have any practical holes to atach it to the wall. And it protrudes at the back a few mmâs, too.
I printed that plate, more out of curiosity, to see how much pins are strong, and, as i suspected, they snapped off pretty soon, after two or three front removals. Iâd say only long-term solution would be to print it âstanding upâ, to ensure that pins are not layered and thus strong.
Hi, is there example if I want to add confirmation window (yes/no) when I click a button?
That would be a cool feature but the button library has nothing like that so far. LVGL does support a construct for pop up messages so it would be possible to implement.
Can you describe the use case? This may be some I work on in the future.
I second that confirmation popup would be an excellent for many things. Why? Well, display is small, and some of âguysâ have big fingers, so wrong touch can happen pretty easily. For example i have icons for my climate pretty small (cool, heat, auto, dry, offâŚ) because i have a lot of things on that screen beside that. So, popups would, for one, allow us to create more dense âdashboardsâ and result in less wrong actions, i guess.
Yeah I already built one for RGB lights. There would be no way to fit all that stuff on a top page. I will do the same for climate control at some point. A second level page to actually change temperature set points etc. I have not found a use case for a yes/no button but it would be very easy to implement. It would probable just be part of a widget that required confirmation not itâs own widget.
That is why I asked for a use case.
