H2 show the brightness level under lights in dashboard in Lovelace?
I would like to show a slider with the brightness level below a light switch. Is this possible in Lovelace?
Yes, with this custom card.
Thanks. It works really well.
Thanks @VDRainer
That link solved a problem I needed to fix myself. I was using @andrey’s custom-ui but it doesn’t seem to work in lovelace (unless I’m doing doing something wrong - which is quite likely).
