Hi I ask this here because there are no changes related to this in the docs of 0.97 and nothing points out (at least to me) that themes have changed in 0.97. I have custom css entries and they worked fine until this version. It does work when I do a service call to change the frontend theme, but setting it on a personal level does nothing except changing the wallpaper. Is custom css no longer supported?
Also I found that changing to default will change the UI colors, but will not affect any other color I set up. Calling a service still works fortunately. Any ideas?
Yes you are right, I am at work that is the reason why I ask here. (And maybe someone already had an answer so that the devs can work on more important stuff haha).
Yes I know it is in beta, but to my knowledge the release of 0.97 is imminent. No hurries, I will go ask it on discord whenever I find the time.
Yeah, it’s only on beta 2. There really should be a beta channel here but I don’t think the devs use the forums often. Best bet is always discord because they are always on.
