HA 17 OS core never updates on RPI 3 - stuck on 2025.11.03
It seems to be a common thread when I search this but no solutions. I am running HA 17 on RPI3 - yes I know it’s not recommended but it’s a temp measure until my Mini PC arrives.
I have quite a small network and it seems to be running fine on the RPI surprisingly…but the one thing it won’t do is update the core/os - but oddly I have managed to update Supervisor somehow to 2026 during one of the update attempts which actually finished - ha core update --version 2026.1.3 --backup but then it didn’t actually update the core, just the supervisor!
This is with the UI - it just constantly span and never finished for many hours - or running ha core update or ha os update in the Terminal. They just go processing…
Oddly it shows no updates now in the UI, even if I select skipped updates, not sure if I somehow toggled the visibility. It’s always been like this from day one, it would not update - so I don’t think it’s anything I’ve added.
I can ping DNS and github…
These log errors:
Logger: homeassistant.components.hassio
Source: components/hassio/websocket_api.py:145
integration: Home Assistant Supervisor
First occurred: 6:45:10 PM (20 occurrences)
Last logged: 7:02:10 PM
  • Failed to to call /core/info -
  • Failed to to call /ingress/session -
  • Failed to to call /store -
  • Failed to to call /host/info -
  • Failed to to call /ingress/validate_session -
Ingress comes up a lot, oddlly…
Logger: homeassistant.components.hassio.handler
Source: components/hassio/handler.py:250
First occurred: 6:45:10 PM (44 occurrences)
  • Timeout on /core/info request
  • Timeout on /ingress/session request
  • Timeout on /store request
  • Timeout on /host/info request
  • Timeout on /ingress/validate_session request
Logger: homeassistant.components.hassio.coordinator
Source: helpers/update_coordinator.py:435
integration: Home Assistant Supervisor (documentation, issues)
First occurred: 6:46:04 PM (2 occurrences)
Last logged: 6:59:23 PM
Error fetching hassio data: Error on Supervisor API:
Logger: aiohttp.server
Source: /usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py:481
First occurred: 6:00:43 PM (40 occurrences)
Last logged: 7:12:08 PM
Error handling request from 192.168.1.65
File “/usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py”, line 408, in data_received
messages, upgraded, tail = self._request_parser.feed_data(data)
File “aiohttp/_http_parser.pyx”, line 556, in aiohttp._http_parser.HttpParser.feed_data
aiohttp.http_exceptions.BadHttpMessage: 400, message:
Data after Connection: close:
b'\x00
First occurred: 6:45:10 PM (58 occurrences)
Last logged: 7:16:13 PM
Timeout on /network/info request
Timeout on /supervisor/stats request
Timeout on /core/stats request
Sounds like your Pi3 is running a 32bit version…
You can’t upgrade that version of OS.
No it’s running the 64 bit version. It’s impossible to install HA 17 on 32 bit (officially, from the OS images anyway), it’s been dropped. It says ‘RPI3 64 bit’ on the Hardware screen and the System Info Aarch64.
There is an official RPI3 64 bit image. Release Home Assistant OS 17.0 · home-assistant/operating-system · GitHub which is what I am using - ‘haos_rpi3-64-17.0.img.xz’.
Although they push the Pi4 or Pi5 as being what you should use cos the Pi3 is 1Gb, it’s not hitting memory limits:
and there’s nothing saying that non-32 bit systems wouldn’t be updateable.
The drop in support/updates is for 32bit, which isn’t what I am running?
Hmm just noticed it now says core2026.1.3 on the System Info I just posted…wonder if it finally did it? Only been trying to update for over a week…
EDIT no - it still stays Processing… in the terminal.
Ooh my Philips Hue appeared for the first time! Don’t tell me I bought a Zigbee dongle for no reason?!?
Hmm it seems to have actually done this time - no idea what fixed it. I did allow some of the 172.30.33.x… range in configuration.yaml - cos seemed to get a lot of the errors about that range:
http:
use_x_forwarded_for: true
trusted_proxies:
- 172.30.33.0/24
and did ‘ha su repair’ before, maybe it was that?
Very strange as I’ve been trying for over a week!
