After preforming the upgrade moments ago, 84.6 seems to have broken the automations when you try to set the temperature.
I can call the service from the dev tools with not problems, copy and paste this into my automation… its broken. I’ve test this by using the “automation.turn_on” service and then call the automation.
I’m having the same problem! This is an automation that used to work without problem. I change the value using an input_number slider to change the target temperature of my generic thermostat. Now it’s not working. I’ve looked through the docs but can’t find any reason for this to stop working!
alias: Presence Cool Temperature Arriving
- entity_id: device_tracker.life360_caleb
platform: state
to: home
- entity_id: device_tracker.life360_carter
platform: state
to: home
- entity_id: device_tracker.life360_dad
platform: state
to: home
- entity_id: device_tracker.life360_mom
platform: state
to: home
condition:
- condition: state
entity_id: sensor.home_thermostat_operation_mode
state: cool
- data:
entity_id: climate.home
temperature: 78
service: climate.set_temperature
I’ve discovered the problem!! For some reason all my automations had been turned off. I know they can be turned on and off from the entity state section but no clue how the whole group can be turned on/off. Anyway, I’ll leave this here, in case anyone has a similar problem.
I wish you had! I’ve made so many daft mistakes with this hassio business now that I’ve lost all embarrassment I’ve never had my automations toggle off before but it’s a good lesson learnt!
Well… what I was doing was going to to the dev tools, and telling it to execute the automation which I thought for sure was working (maybe that is a bug). So, I went back to my dashboard, click the menu, then hit trigger. Everything worked Rrrrrr.
