Hello, here my Solution to read the Bresser Temp Sensors from LM Air.
in my configuration.yaml i have the call for my
sensor: !include lma_sensor.yaml
sensors:
channel0_temperature:
friendly_name: "LMAir Direct"
value_template: '{{ states.sensor.csensor.attributes["channel0"]["temperature"] }}'
device_class: temperature
unit_of_measurement: '°C'
channel6_temperature:
friendly_name: "Kitchen"
value_template: '{{ states.sensor.csensor.attributes["channel6"]["temperature"] }}'
channel6_humidity:
value_template: '{{ states.sensor.csensor.attributes["channel6"]["humidity"] }}'
device_class: humidity
unit_of_measurement: '%'
channel7_temperature:
friendly_name: "Room3"
value_template: '{{ states.sensor.csensor.attributes["channel7"]["temperature"] }}'
channel7_humidity:
value_template: '{{ states.sensor.csensor.attributes["channel7"]["humidity"] }}'
channel8_temperature:
friendly_name: "Outside2"
value_template: '{{ states.sensor.csensor.attributes["channel8"]["temperature"] }}'
channel8_humidity:
value_template: '{{ states.sensor.csensor.attributes["channel8"]["humidity"] }}'
# channel9_temperature:
# friendly_name: "empty"
# value_template: '{{ states.sensor.csensor.attributes["channel9"]["temperature"] }}'
# device_class: temperature
# unit_of_measurement: '°C'
channel10_temperature:
friendly_name: "Outside1"
value_template: '{{ states.sensor.csensor.attributes["channel10"]["temperature"] }}'
channel10_humidity:
value_template: '{{ states.sensor.csensor.attributes["channel10"]["humidity"] }}'
channel11_temperature:
friendly_name: "Extern"
value_template: '{{ states.sensor.csensor.attributes["channel11"]["temperature"] }}'
I am very happy that this works!
This is a Trying,playing, Get-IT Solution
during the last Lockdown.
LG Werner
Hallo Werner,
sorry, but I found your old topic here and have a question.
Isn´t there something missing for explanation?
How is ist possible to get the Sensors from the weather.json dataset posted by the Lightmanager?
I really would like to integrate the sensors from Lightmanager into Homeassitant.
Could youe please give me some more hints?
Thanks and best regards,
Henning
Many Thanks for your help! Finally it worked with the following entities.
#Lightmanager Sensoren
- platform: rest
resource: http://your.LM.IP/weather.json
username: XXXXXXX
password: XXXXXXX
value_template: 'OK'
scan_interval: 10
json_attributes:
- channel0
- channel5
- channel6
- channel7
- channel9
- channel10
- channel11
sensors:
windrichtung:
value_template: >
{% set direction = ['N','NE','E','SE','S','SW','W','NW','N'] %}
{% set degree = states('sensor.channel11_wind_direction')|float %}
{{ direction[((degree+20)/40)|int] }}
sensors:
channel0_humidity:
value_template: '{{ states.sensor.csensor.attributes["channel0"]["humidity"] }}'
channel5_temperature:
friendly_name: "Badezimmer Temperatur"
value_template: '{{ states.sensor.csensor.attributes["channel5"]["temperature"] }}'
channel5_humidity:
friendly_name: "Badezimmer Feuchtigkeit"
value_template: '{{ states.sensor.csensor.attributes["channel5"]["humidity"] }}'
friendly_name: "Terrassentuer Temperatur"
channel6_humidity:
friendly_name: "Terrassentuer Feuchtigkeit"
friendly_name: "Wohnzimmer Temperatur"
channel7_humidity:
friendly_name: "Wohnzimmer Feuchtigkeit"
friendly_name: "Külschrank Temperatur"
channel9_humidity:
friendly_name: "Kühlschrank Feuchtigkeit"
value_template: '{{ states.sensor.csensor.attributes["channel9"]["humidity"] }}'
friendly_name: "Arbeitszimmer Temperatur"
channel10_humidity:
friendly_name: "Arbeitszimmer Feuchtigkeit"
friendly_name: "Wetterstation Temperatur"
channel11_humidity:
friendly_name: "Wetterstation Feuchtigkeit"
value_template: '{{ states.sensor.csensor.attributes["channel11"]["humidity"] }}'
channel11_wind_geschwindigkeit:
friendly_name: "Wetterstation Windgeschwindigkeit"
value_template: '{{ states.sensor.csensor.attributes["channel11"]["wind"] }}'
device_class: wind_speed
unit_of_measurement: 'km/h'
channel11_wind_direction:
friendly_name: "Wetterstation Windrichtung in Grad"
value_template: >
{{ states.sensor.csensor.attributes["channel11"]["direction"] }}
unit_of_measurement: '°'
channel11_rain:
friendly_name: "Regenmenge"
value_template: >
{{ states.sensor.csensor.attributes["channel11"]["rain"] }}
unit_of_measurement: 'mm/h'
