I have small pattern - ‘forget timer’ that make delay to switch off lamp if I forget to switch it off.
I’d like to use this pattern for all wall switches. I have saw an example and adopt it to my situation:
- id: forget timer for button
alias: Таймер забывчивости для выключателя
- entity_id:
- switch.01005156bcddc26070bc_1
- switch.01005156bcddc26070bc_2
platform: state
to: 'on'
- delay: '[object Object]'
- data_template:
entity_id: '{{ trigger.entity_id }}'
service: switch.turn_off
But problem is - here are one timer for all events and last event get priority - drop timer and use action only for last device.
How i can make separate timers and actions for each device with a smart and short code like above or I should make ‘hard style’ (multiply same code block for each device)?
