HA Boot Loop after adding 4th cam in MotionEye
Been running HA for a few years, enjoying adding new devices with each update, and sad when a vendor takes away functionality from HA. I had some extra time and wanted to work with MotionEye, even though my cams were added to HA and integrated in some of the pages I setup. I added the 4th Reolink cam, a mix of 4k and the battery powered ones, and it sent my HA in to a boot loop. I would like to know how to stop the boot loop and load the last backup, or eliminate MotionEye. Right now HA boots, stays up for a few min then reboots. Any help is appreciated. I know enough to follow instructions and setup and configure HA, but not enough to know which file to edit, or how to stop the boot loop.
Hi Eric, welcome to the forum.
Have you tried to start your system in safe mode?
Hey Nick,
Yes, I did manage to find out how to start in safe mode from the webpage, and it has the same behavior.
It can be helpful to share some info about your setup.
HA is running on a raspberry pi 3, core v2024.6.2, Supervisor v2024.06.2, OS v12.3 Frontend v20240610.0. Is there a file or screenshot I can take and post to give more info?
Isn’t that a little to much for a RPi3?!
If you are in safe mode, is nothing loaded regarding your cams?
Are you using a SSD or SD card?
I thought that could be the issue, so I want to kill off MotionEye all together. I was running fine without any cams setup. It is on an SD card.
This is the log from Supervisor, or all of it I can get from the webpage before the reboot.
[21:55:59] INFO: e[32mUsing udev information from hoste[0m
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
s6-rc: info: service legacy-services successfully started
[21:55:59] INFO: e[32mStarting local supervisor watchdog...e[0m
e[32m2024-06-27 21:56:08.282 INFO (MainThread) [__main__] Initializing Supervisor setupe[0m
e[32m2024-06-27 21:56:08.614 INFO (MainThread) [supervisor.utils.sentry] Initializing Supervisor Sentrye[0m
e[32m2024-06-27 16:56:08.645 INFO (MainThread) [supervisor.bootstrap] Setting up coresys for machine: raspberrypi3-64e[0m
e[32m2024-06-27 16:56:08.668 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/aarch64-hassio-supervisor with version 2024.06.2e[0m
e[32m2024-06-27 16:56:08.744 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initializee[0m
e[32m2024-06-27 16:56:08.754 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation completee[0m
e[32m2024-06-27 16:56:08.757 INFO (MainThread) [__main__] Setting up Supervisore[0m
e[32m2024-06-27 16:56:09.106 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2e[0m
e[32m2024-06-27 16:56:09.348 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitore[0m
e[32m2024-06-27 16:56:09.355 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.e[0m
e[32m2024-06-27 16:56:09.357 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.ose[0m
e[32m2024-06-27 16:56:09.360 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1e[0m
e[32m2024-06-27 16:56:09.363 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1e[0m
e[32m2024-06-27 16:56:09.368 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManagere[0m
e[32m2024-06-27 16:56:09.371 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauce[0m
e[32m2024-06-27 16:56:09.375 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1e[0m
e[32m2024-06-27 16:56:09.378 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1e[0m
e[32m2024-06-27 16:56:09.381 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1e[0m
e[32m2024-06-27 16:56:10.324 INFO (MainThread) [supervisor.host.services] Updating service informatione[0m
e[32m2024-06-27 16:56:10.349 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio informatione[0m
e[33m2024-06-27 16:56:10.369 WARNING (SyncWorker_0) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio servere[0m
e[33m2024-06-27 16:56:10.381 WARNING (MainThread) [supervisor.host.network] Requested to update interface enu1u1 which does not exist or is disabled.e[0m
e[32m2024-06-27 16:56:10.386 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}e[0m
e[32m2024-06-27 16:56:10.431 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitore[0m
e[32m2024-06-27 16:56:10.433 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.jsone[0m
e[32m2024-06-27 16:56:10.620 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2024.05.0e[0m
e[32m2024-06-27 16:56:10.726 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugine[0m
e[32m2024-06-27 16:56:10.756 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_cli applicatione[0m
e[32m2024-06-27 16:56:12.922 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/aarch64-hassio-cli with version 2024.05.0 - 172.30.32.5e[0m
e[32m2024-06-27 16:56:12.991 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2024.04.0e[0m
e[32m2024-06-27 16:56:13.167 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugine[0m
e[32m2024-06-27 16:56:13.197 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_dns applicatione[0m
e[32m2024-06-27 16:56:16.009 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/aarch64-hassio-dns with version 2024.04.0 - 172.30.32.3e[0m
e[32m2024-06-27 16:56:16.014 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.confe[0m
e[32m2024-06-27 16:56:16.047 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0e[0m
e[32m2024-06-27 16:56:16.109 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugine[0m
e[32m2024-06-27 16:56:16.164 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_audio applicatione[0m
e[32m2024-06-27 16:56:23.142 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0 - 172.30.32.4e[0m
e[32m2024-06-27 16:56:23.160 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-observer with version 2023.06.0e[0m
e[32m2024-06-27 16:56:23.227 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-multicast with version 2024.03.0e[0m
e[32m2024-06-27 16:56:23.289 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugine[0m
e[32m2024-06-27 16:56:23.314 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_multicast applicatione[0m
e[32m2024-06-27 16:56:25.618 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/aarch64-hassio-multicast with version 2024.03.0 - Hoste[0m
e[32m2024-06-27 16:56:25.647 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 1 Home Assistant secretse[0m
e[32m2024-06-27 16:56:25.660 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/raspberrypi3-64-homeassistant with version 2024.6.2e[0m
e[32m2024-06-27 16:56:26.048 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 12.3 / BootSlot Ae[0m
e[32m2024-06-27 16:56:28.674 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repositorye[0m
e[32m2024-06-27 16:56:28.676 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/d5369777 repositorye[0m
e[32m2024-06-27 16:56:28.678 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repositorye[0m
e[32m2024-06-27 16:56:28.683 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repositorye[0m
e[32m2024-06-27 16:56:30.388 INFO (MainThread) [supervisor.store] Loading add-ons from store: 80 all - 80 new - 0 removee[0m
e[32m2024-06-27 16:56:30.633 INFO (MainThread) [supervisor.addons.manager] Found 3 installed add-onse[0m
e[32m2024-06-27 16:56:30.735 INFO (MainThread) [supervisor.docker.interface] Attaching to homeassistant/aarch64-addon-configurator with version 5.8.0e[0m
e[32m2024-06-27 16:56:30.751 INFO (MainThread) [supervisor.docker.interface] Attaching to homeassistant/aarch64-addon-ssh with version 9.14.0e[0m
e[32m2024-06-27 16:56:30.771 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/motioneye/aarch64 with version 0.20.0e[0m
e[32m2024-06-27 16:56:30.983 INFO (MainThread) [supervisor.backups.manager] Found 119 backup filese[0m
e[32m2024-06-27 16:56:31.864 INFO (MainThread) [supervisor.discovery] Loaded 1 messagese[0m
e[32m2024-06-27 16:56:31.865 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessionse[0m
e[32m2024-06-27 16:56:31.865 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setupe[0m
e[32m2024-06-27 16:56:31.866 INFO (MainThread) [supervisor.resolution.checks.base] Run check for detached_addon_missing/addone[0m
e[32m2024-06-27 16:56:31.867 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/systeme[0m
e[32m2024-06-27 16:56:31.867 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/systeme[0m
e[32m2024-06-27 16:56:31.868 INFO (MainThread) [supervisor.resolution.checks.base] Run check for detached_addon_removed/addone[0m
e[32m2024-06-27 16:56:31.869 INFO (MainThread) [supervisor.resolution.check] System checks completee[0m
e[32m2024-06-27 16:56:31.869 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setupe[0m
e[32m2024-06-27 16:56:31.872 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation completee[0m
e[32m2024-06-27 16:56:31.874 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setupe[0m
e[32m2024-06-27 16:56:31.880 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setupe[0m
e[32m2024-06-27 16:56:31.882 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation completee[0m
e[32m2024-06-27 16:56:31.887 INFO (MainThread) [__main__] Running Supervisore[0m
e[32m2024-06-27 16:56:31.919 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as goode[0m
e[32m2024-06-27 16:56:31.971 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' starting 0 add-onse[0m
e[32m2024-06-27 16:56:31.995 INFO (MainThread) [supervisor.addons.manager] Phase 'system' starting 0 add-onse[0m
e[32m2024-06-27 16:56:32.996 INFO (MainThread) [supervisor.addons.manager] Phase 'services' starting 1 add-onse[0m
e[32m2024-06-27 16:56:32.111 INFO (SyncWorker_6) [supervisor.docker.manager] Cleaning addon_core_ssh applicatione[0m
e[32m2024-06-27 16:56:33.993 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-ssh with version 9.14.0e[0m
e[32m2024-06-27 16:56:39.022 INFO (MainThread) [supervisor.core] Start Home Assistant Coree[0m
e[32m2024-06-27 16:56:39.101 INFO (SyncWorker_0) [supervisor.docker.manager] Starting homeassistante[0m
e[32m2024-06-27 16:56:39.877 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is readye[0m
e[32m2024-06-27 16:57:03.743 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state startupe[0m
e[32m2024-06-27 16:57:03.744 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation completee[0m
e[32m2024-06-27 16:57:05.014 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API tokene[0m
e[32m2024-06-27 16:57:05.040 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to NOT_RUNNINGe[0m
e[33m2024-06-27 16:57:15.530 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f7ed188c0>: Failed to establish a new connection: [Errno 111] Connection refused')': /api/5370612/envelope/e[0m
e[33m2024-06-27 16:57:15.536 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f7ed19dc0>: Failed to establish a new connection: [Errno 111] Connection refused')': /api/5370612/envelope/e[0m
e[33m2024-06-27 16:57:15.543 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f7ed18260>: Failed to establish a new connection: [Errno 111] Connection refused')': /api/5370612/envelope/e[0m
e[32m2024-06-27 16:58:01.660 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to RUNNINGe[0m
e[32m2024-06-27 16:58:01.661 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instancee[0m
e[32m2024-06-27 16:58:01.663 INFO (MainThread) [supervisor.addons.manager] Phase 'application' starting 2 add-onse[0m
e[32m2024-06-27 16:58:01.848 INFO (SyncWorker_4) [supervisor.docker.manager] Cleaning addon_core_configurator applicatione[0m
e[32m2024-06-27 16:58:07.348 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-configurator with version 5.8.0e[0m
e[32m2024-06-27 16:58:07.616 INFO (SyncWorker_3) [supervisor.docker.manager] Cleaning addon_a0d7b954_motioneye applicatione[0m
e[32m2024-06-27 16:58:10.674 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/motioneye/aarch64 with version 0.20.0e[0m
e[33m2024-06-27 16:58:15.649 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f7ed2d490>: Failed to establish a new connection: [Errno 111] Connection refused')': /api/5370612/envelope/e[0m
e[33m2024-06-27 16:58:15.708 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f7ed2e000>: Failed to establish a new connection: [Errno 111] Connection refused')': /api/5370612/envelope/e[0m
e[33m2024-06-27 16:58:15.718 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f7ed2c650>: Failed to establish a new connection: [Errno 111] Connection refused')': /api/5370612/envelope/e[0m
