HA can't connect to netgear tracker
I was learning HASS, restarting HASS a lot. Seems like my Netgear is blocking, maybe restarted too often. Is there a way to fix this or unblock it? I tried specifying port 80 in device_tracker.yaml file same error.
16-08-24 19:05:40 pynetgear: Error talking to API
ConnectionRefusedError: [Errno 111] Connection refused
MaxRetryError: HTTPConnectionPool(host=‘10.8.8.1’, port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError(’<requests.packages.urllib3.connection.HTTPConnection object at 0x71d3eff0>: Failed to establish a new connection: [Errno 111] Connection refused’,))
have you tried restarting your router? Most likely there the problem exists.
HA has automatic discovery component already for Netgear so I removed my manual entry. No error in logs yet this morning.
I haven’t restarted router yet will do that if message comes up again. Thx!
