HA config folder and git branch
Hi All,
Does someone know if you can use a different branch on the config folder to do some tests?
Normally I edit the yaml file and test it. Commit to git.
But sometimes I want make big changes and try something new for everything.
I thought when I create a new branch. So I can work in that one and see what happen… if not move back to the main.
Im not a star with git but know the basic commands… :slight_smile:
Yes, simply create a new branch using the terminal commands in the HA config folder to create a local branch (note I’m checking out the main branch first, yours might be master):
git checkout main
git checkout -b my-branch-name
If you want you can push the branch to your repo and then use the Github Website to create a Pull request back to your main or master branch
git push origin my-branch-name
Once you complete the pull request switch the HA Config back to the main / master branch:
git switch main
note: the switch command is in Git v2.23.0 or later - if you are using an earlier version just use ‘git checkout main’
You can delete your test branch from the local HA config using:
git branch -d my-branch-name
Note: this checks if the branch is fully merged with the upstream. If you use ‘-D’ instead of ‘-d’ it will force the delete.
Thank you for the clean explanation !!! This helped me out.
Now I can do some big tests without changing the master branch :slight_smile:
//never to old to learn
