HA config has disappeared!
I really hope someone can help me here but I fear that I know the outcome already :frowning:
This morning I look at my config folder and it looks like this:
ha_config
My entire config has disappeared. I had a scrips folder with multiple script files, same with automations, etc. The last thing I was doing last night was just general config changes but everything seemed fine. Ironically I was trying to setup the Git Pull HASSIO add-in to get some off-site backups of my config but I couldn’t get this to work so bailed and uninstalled the add-on.
The only backup I have is a snapshot I took within HASSIO but this is two weeks old. Is there any way to view the contents of my automations, scripts, etc. from the front end? When I try to edit them I am told that they cannot be edited as they are not in the default script.yaml and automation.yaml files.
The strange thing though is that my config still seems to be working, I have just tested a few automations and they fired. I haven’t restarted HASSIO yet. Has anyone seen this before? I also don’t understand how anything can still be working when my db is only 4KB so clearly it doesn’t contain the usual contents. Have my files been re-located somewhere else?! I have only been using HASSIO since January but it has been so stable compared to what I used to run. This is the first time anything like this has happened. I am running 0.111.3.
Any help is appreciated. Many thanks.
Are you sure windows is not “hiding” files?
No.
Thanks for the responses.
I ended up biting the bullet, restarting HASSIO and, unsurprisingly, the config was gone and it booted like a fresh install. I had to restore my snapshot from two weeks ago. I still don’t understand what caused it.
Oh well, guess it is a lesson in having backups :-/
That method still relies on the files existing in the config folder. Read the whole question, not just the bit I quoted.
Just like that. FYI I did read the whole question. I just thought “no” isn’t helpful and also not true.
Just like what?
Ok perhaps should have said “comprehend the whole question”.
It is true and to the point for the question in this topic. I saw no reason to waffle on about something that can’t be done.
My other post I deleted.
True, but then again all possible places HA can act on are very much visible in vscode add-on. If the files are out of the scope of vscode they are also out of the scope of HA.
I use the VSCode addon. It’s not a matter of the files being “out of scope”. They no longer existed, so they could not be recovered with VSCode.
Let me change the subject slightly :wink:
I have the VSCode add-in too but I have it ‘not started’ and I only keep it as I thought it might be useful one day if I am away from home and for some reason absolutely needed to edit something in my config. It has never happened.
I am just wondering, what are the benefits in using the add-on rather than a separate install of VSCode on a separate PC?
No advantage when home, but when 5000km from home I can edit my config easily without having to remote into my home server.
I usually keep it not started until needed.
Help. I seem to have run into the same issue, except I have regular backups.
When I use Terminal I see nothing in the config folder, but I can reboot HA without an issue. Thge backups are all there, but there is nothin in the config folder.
I also do not see any files in Visual Studio Code.
I thought I would try to create a test file using VSC, which I called test.yaml, and got the following error message. Hopefully this gives enough clues.
