HA (container) found Zigbee but not Zwave when both are on the same stick
I have a HUSBZB-1 USB stick. I plugged it into my host and updated my Docker compose.
When I started HA, it auto found the Zigbee but not Z-Wave. I can’t tell what I’m doing wrong.
    homeassistant:
        image: "ghcr.io/home-assistant/home-assistant:stable"
        hostname: homeassistant
        container_name: homeassistant
        network_mode: host
        restart: unless-stopped
        privileged: true
        volumes:
            - /home/docker/homeassistant:/config
            - /etc/localtime:/etc/localtime:ro
            - /run/dbus:/run/dbus:ro
        devices:
            - /dev/ttyUSB0
            - /dev/ttyUSB1
Because that’s not how you run Z-Wave with HA. You would use Z-Wave JS UI in a different container.
https://www.home-assistant.io/integrations/zwave_js/#advanced-installation-instructions
https://zwave-js.github.io/zwave-js-ui/#/getting-started/quick-start
Also, you’re asking for trouble by using /dev/ttyUSB0 and /dev/ttyUSB1. Those could easily swap next time you reboot and then nothing will work. Use the /dev/serial/by-id paths instead.
OHHHHHHHHHHHHH. I was using HA OS before but moved to Docker and didn’t realize I had to run it myself. Thanks!
