I attempted a container upgrade to 2025.3.1, which has gone fine before many times. I run a rootless container using podman. However now I get this odd crash:
baggypants@pod-vm:~/.local/share/containers/storage/volumes/ho-ass/_data$ cat home-assistant.log
2025-03-10 14:18:38.685 ERROR (MainThread) [root] Uncaught exception
File "<frozen runpy>", line 198, in _run_module_as_main
File "<frozen runpy>", line 88, in _run_code
File "/usr/src/homeassistant/homeassistant/__main__.py", line 227, in <module>
sys.exit(main())
File "/usr/src/homeassistant/homeassistant/__main__.py", line 213, in main
exit_code = runner.run(runtime_conf)
File "/usr/src/homeassistant/homeassistant/runner.py", line 154, in run
return loop.run_until_complete(setup_and_run_hass(runtime_config))
File "/usr/local/lib/python3.13/asyncio/base_events.py", line 725, in run_until_complete
return future.result()
File "/usr/src/homeassistant/homeassistant/runner.py", line 122, in setup_and_run_hass
hass = await bootstrap.async_setup_hass(runtime_config)
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 342, in async_setup_hass
await async_from_config_dict(config_dict, hass) is not None
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 478, in async_from_config_dict
await async_load_base_functionality(hass)
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 447, in async_load_base_functionality
await asyncio.gather(
...<13 lines>...
File "/usr/src/homeassistant/homeassistant/helpers/entity_registry.py", line 1538, in async_load
await async_get(hass).async_load()
File "/usr/src/homeassistant/homeassistant/helpers/entity_registry.py", line 1393, in async_load
original_device_class=entity["original_device_class"],
KeyError: 'original_device_class'
Things I’ve tried:
- reverting to the previous image 2025.2.0
- attemting to run with the image version 2025.2.5
- removing
custom_components
- removing
deps
- removing the
home-assistant_v2.db*
files - creating a new container volume and restoring from a backup
- This was interesting as the container did start fine, but then the exact same crash message appeared partway through the restore, which tells me it’s something in my config directory causing the issue.
- removing the contents of
python_scripts
Anyone recognise the crash dump and point me to a possible culprit?
