HA Container - MyHome - Virtual light 0106 receives feedback as 16 on MH201
I use the MyHOME custom integration with an MH201 gateway.
The light is configured with the virtual OpenWebNet address 0106 (this happens with all lights configured in myhome.yaml).
The light can be controlled correctly from Home Assistant when configured as ’ where: “0106” ',
using where: "16" does not control the light correctly.
The integration logs:
Message received: `*1*1000#1*16##`
Ignoring translation message `*1*1000#1*16##`
Message received: `*1*1*16##`
The entity configured with where: "0106" remains unknown.
The command session is established successfully.
The Bitdomo app connects to the same MH201 gateway and correctly controls and reads the state of this virtual light.
